Does size really matter?
/ Does size really matter? #21
Mad,
Not to be nit-picky, I just thought I might shed some light on your question pertaining to how flow in ft/sec relates to PSI. In short, it doesn't. What those numbers represent is ideal conditions conducive to laminar flow, if I recall correctly. It has been a while since I took Fluid Power in college but I believe that is what those numbers represent.
In all reality there is minimal pressure present in a line when there is flow, it is when you stop the flow that you begin to build pressure. A pump doesn't create pressure, it merely creates flow. When that flow is impeded, you get pressure. So the size of the line up until that point has almost nothing to do with pressure just how "good" the fluid flows through it.
Now, if the line is too small and your pump/motor output is high you will get turbulent flow in that line, which is inefficient at best and can lead to high temps and premature breakdown of the fluid at worst. By going to the next size up line you ensure that if you have a high output pump you are taking full advantage of the speed afforded you while not creating flow problems.
Once the pressure starts to build it is actually sometime better to be using a smaller diameter line/hose as the hoop stress is not as great (smaller diameter = smaller surface area for the liquid to act on inside the line/hose).
If'n you already knew this, sorry. Don't mean to preach to the choir. Also, if my "technical" jargon is off, again sorry. It's beena few years since I worked on hydraulics, I'm a bit rusty (no pun intended!) /forums/images/graemlins/grin.gif.
Hope this helps.
/ Does size really matter? #22
Mad,
Hope this helps.
/ Does size really matter? #23
Thanks, no problem. I understand the physics, it's just that I didn't quite understand the reasoning for the rating in ft/sec.
/ Does size really matter? #24
PAB_OH,
I'm impressed. Theoretical question for you. Same cylinder, same load, same 12.5 gpm pump, same max pressure 2,850 psi -- does the 1/2" flex-line extend the cylinder faster than the 3/8" flex-line? Or asked another way -- does the 3/8" flex-line restrict the flow enough or cause enough turbulence that the cylinder takes longer to extend than if a 1/2" flex-line is used? I think the answers to these questions are what I'm after.
The level of knowledge available on forums like TBN never ceases to amaze me.
Zoom
PAB_OH,
Zoom
/ Does size really matter? #27
ugggh!
Off the top of my head, ALL things being equal, the answer is no. I mean all things! The coefficient of flow for alll the fittings would have to be the same etc...
Obviously if you have a 1/2" flex line then you have a 1/2" fitting for it coming off your ridgid line which is probably 3/8", I'm assuming. I think the "K" factor for a 1/2" fitting is probably higher (or lower, can't rememeber which is better right now) than that of a 3/8" fitting. Basically using the bigger fitting and line will only HELP to ensure you don't create turbulent flow.
In reality, in a system this small (almost all CUT's) I would THINK that the any gain seen in speed would be minimal and is largely based more on the GPM of the pump. The big thing to avoid is long runs of narrow line, especially flex line. The ridgid line (SS tube for instance) is very smooth inside relative to hose and in addition hose can and will be bent, causing directional changes that will induce turbulence.
I hope I'm helping and not making it more confusing. Also, if anyone catches errors correct me. I feel like I'm skating on thin ice. It really has been some time since I've worked through one of these problems let alone "thunk on" the physics behind it.
/ Does size really matter? #28
ugggh!
/ Does size really matter? #29
</font><font color="blue" class="small">( does the 3/8" flex-line restrict the flow enough or cause enough turbulence that the cylinder takes longer to extend than if a 1/2" flex-line is used?)</font>
I can't speak for 1/2" to 3/8" but some of us typically use 1/4" hose for controlling the top link. The 1/4" hose provides sufficient restriction to slow down the cylinder movement to allow for feathering. Using 3/8" hose will definitely make the cylinder move significantly faster.
Based on this actual application, I would have to say that a smaller hose would slow down the movement of the cylinder, given all else was equal.
/ Does size really matter? #30
/ Does size really matter? #31
MAD is probably right about this. THe more I think about the more it makes sense that bumping the fitting up to 1/2" allows for more fluid, that is the whole point generally of using larger lines - volume. And vollume = speed, all else equal.
/ Does size really matter? #32
/ Does size really matter? #33
Gotta jump in here...
IF the pump/system design (ie GPM) is not a limiting factor, the larger hoses should give faster cylinder movement.
Think about it. A cylinder has a FIXED volume on both inlet and outlet that must be moved into/outof the body to actuate the cylinder. Everybody understands that part.
A larger hose will move this volume more quickly, assuming the pump is up to the GPM required.
This is also assuming pressure is not an issue.
Normally, I would recommend hardlining larger lines as far as practical for reliability and for extending "Maximium pump performance" before going into valves, fittings, or flexlines. Generally, the larger the line, the longer it can extend without performance loss...generally.
There are limits and other factors, so this is not carved in stone, but generally true from a design point.
If in the end it doesn't perform fast enough, pick a good tune to hum while working- it seems to go faster that way! /forums/images/graemlins/grin.gif
