does my tractor have draft control??
/ does my tractor have draft control?? #1
yukonhunter
leroy ny
John deere 5100m, mf1643 cab and kubota bx2370woods bb720x land pride disc and reverse tiller
I have a new jd4066r and just bought a new two row planter and they asked me if I have draft control, where the implement flows with the ground...not sure if I do or not?
/ does my tractor have draft control?? #2
I don't know your tractor, but do you have two 3PH levers?
Steve
No just one
/ does my tractor have draft control?? #4
My tractor with draft control (TN55) has two levers -- one for position control and one for draft control. I'm no expert, but I thought draft control requires a separate lever/control.
Steve
Hmm...I wonder if I can add it as an option
/ does my tractor have draft control?? #6
I think it would be easier to add gauge wheels to planter than draft control to tractor hyd system.
I do know mybtractor comes with down pressure
/ does my tractor have draft control?? #8
The 4 series do not have draft control
But I would like to know more about the down pressure option. How does it work?
/ does my tractor have draft control?? #9
I too would like to know how a 4520 has down pressure on 3 pt seeing that RS piston rod isn't attached to RS piston. I bet with 3 pt hitch lowered with nothing attached one can lift 3 pt draft arms.
/ does my tractor have draft control?? #10
I've been sorta guessing that it is basically 2 hydraulic side links, and a way to lock the rockshaft in place. I've been wanting to see some pictures since they came out with the option.
JCB 3TS TELESKID (A65056)
JCB 3TS TELESKID...
2008 THE MACHINE CO. THAWZALL H250 HEATER  (INOPERABLE) (A68842)
2008 THE MACHINE...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
SPARTAN XBC173072-72" HYD BRUSH CUTTER (A65056)
SPARTAN...
CATERPILLAR 920 WHEEL LOADER (A65056)
CATERPILLAR 920...
2011 INTERNATIONAL PROSTAR (A67714)
2011 INTERNATIONAL...
