Does HP matter?
/ Does HP matter? #41
Well, against my better judgment, lets break it down one more time.
If torque is the same, work that CAN be done is the same.
You disagree with this.
Torque is defined as twisting force. If two engines have the same torque, they have the same amount f twisting force.
Work that needs done requires twisting force to accomplish. If the two engines are able to apply the SAME twisting force the work they are "able" to do is the same. (regardless of how fast they can apply that twisting force)
If you have to accomplish work that needs 100ft lbs of torque to accomplish, and you have a 99ft lb engine, it simply isnt going to get it done regardless of weather it has 10hp or 100hp.
Now what of that do you disagree with and why??
If you can gear the the higher HP machine to do more work, you can ALSO gear the lower HP machine to do just as much work. (IF the engine starts off with the same torque)
As in the example above, say you have work that needs done and requires 100ft lbs of torque. and you have 2 engines with 99ft-lbs. One with 10hp and the other with 100. Neither will do the work. But If you add a gearbox to boost the torque, now they will BOTH do the work. But the 100hp engine will simply be 10 times faster.
It dont matter HOW much torque is required to do the work, you can always add gearboxes to get it done. You can add a 100:1 gearbox to the 10hp engine just the same as the 100 hp engine and the end result will still be the same torque.
So when I say that you can gear both the high AND low HP engines to accomplish the work at hand, you diagreed. Care to elaborate as to why?
You can ALWAYS gain torque by gearing. Thats no secret. But HP remains constant (minus a little frictional losses).
And the RPM's have nothing to do with the time element of HP. All the RPM's mean is THAT is the point that they measured the HP. Two totally different things. RPM is just the point at which the measurment is taken.
You can take a 100hp engine with 100ft lbs of torque, and then you can take a 20hp engine with the SAME 100ft-lbs, and the work they are ABLE to do is exactally the same. The 100hp engine will just be quicker is all.
This was in response to another poster. They were saying that a figure like "32hp @ 2500rpm", that the 2500rpm was already the "time element" or HP. But it is simply the point at which the measurement was taken. Whats wrong with that? I suppose that since torque is listed as something like "80ft-lbs @ 1600rpm", that torque also has a time element???
Kinda reverts back to my example in the second part of this post. I dont see why you think it is wrong?
Same torque = same work that "CAN" be accomplished.
Added HP just makes it get accomplished faster.
/ Does HP matter? #42
Against my better judgement, Apologize for your previous insults, and I'll take the time to explain.
/ Does HP matter? #43
LD1 and DarkBlack,
You guys need to speed up your responses:licking: I ain't got al night.:laughing:
/ Does HP matter? #44
For me it weight is important. For example my uncle has a 35HP JD and my 28HP Jinma weighs nearly 2000# more and will just flat out pull it. Yes, he has more PTO HP but he was flat amazed when I brought my tractor over to his house to move some dirt and gravel with him. He now calls me for help pushing our bigger snows.
Chris
/ Does HP matter? #45
SPYDERLK said:
... How about HP will always be half the Torque at 2626. He'll be more comfortable with that. :D
Very true. My point was that the formula cannot be disputed. Torque at working rpm is all that matters. My weed eater makes a lot of HP but very little torque. I would hate to gear that motor down and put it in a tractor though and have to listen to it scream. I had a similar discussion a while back about the ram hemi making more HP than the cummins diesel but the cummins makes a lot more torque. The hemi could do the same work faster but only if you can maintain that constant peak HP rpm(5600 rpms). No thanks.
/ Does HP matter? #46
I would really like to. But you have given me no reason to. Your last two posts since I allegedly insulted you kinda prove that.
You have yet to contribute anything useful. You are just standing in the back of the room, and occasionally saying "your wrong" with absolutely nothing to go with it. I dont even know why I bothered responding to you in the first place:mur: And I dont know why you are even posting in the thread. Saying "your wrong" does nothing to help out any other TBN members, and when thats ALL you say, in turns into confrontation and childish arguing because that is called trolling. You are just trolling along and looking for an argument or debate. IF you werent, you would have explained yourself the first time. I tried. But it seems you dont want to have an grown up discussion and insist on keeping it childish.
I'm done
Moving on..........
/ Does HP matter? #47
I agree and would add another non-technical comment, torque will get you there, HP keeps you there. What I mean is torque is the power to accelerate, etc...but HP allows you to maintain the work / speed etc...
That is why in the automotive world Torque is all important for 0-60 times but HP is critical for Top Speed numbers.
So yes it does matter, (but only if you actually will use those extra horses).
Do you have that backwards? You can pretty accurately calculate HP from 1/4 mile times, you can't do that to find torque.
Or is that not right? (seriously, I'm not sure!)
/ Does HP matter? #48
Honestly, I don't find HP vs Torque thinking very meaningful in the vacuum of not knowing the gearbox characteristics and the users desired performance.
If a person says something I disagree with, frequently I find it is best to just say what I believe is true in an completely independent post. In Friendly Politics, we almost always quote the other person, highlight what we are commenting on, and then tell them they are wrong, and exactly why they are wrong. It's little wonder that approach is reserved for a semi-private forum.
In most other forums, many of us do have a desire to have correct information put forward to avoid misleading our members. That function can be adequately served by individuals writing their own separate posts stating the truth about matters. That approach helps to avoid the boring and annoying process of unwinding previous posts, re-quoting them, and then debating the context, and even the meaning of words. :(
From a strict physics point of view, many of the posts in this thread were somewhat unfortunate because many of the words have both strict physics meanings and common usage meanings. It was pretty clear to me that many of you were mostly meaning the common usage definition. But really, who cares. If anyone has any doubts they have gotten the correct idea, speak up and I'm sure correct assertions will be made to clear up any misunderstanding. But I do believe that most of you did and do understand.
It should be remembered that unlike most cars, most tractors tend to have a governor that is attempting to hold the engine speed the user has set. That governor will provide more or less fuel to try the keep the engine at the set speed. So in most cases, a tractor engine will be somewhat of a torque exercise rather than a HP exercise (the designer already made your gearbox decision.) My car has a five speed, and I go through all the gears during each change of the light. This is a totally different usage, and HP is a big part of it. But when I am in 5th cruising down the highway, torque is a big deal since I really just want to hold my road speed, much like a tractor does nearly all it's life...it mostly it trying to hold your set speed against varying load conditions.
/ Does HP matter? #49
Chris
Without weight, you can have no traction. I guess that is for another class. :confused2:
/ Does HP matter? #50
One thing to remember is that acceleration follows the torque curve and I think that is what was meant. You are correct with the common calculation from the strip. They make assumptions on aerodynamics and gear losses etc and now you enter the time element which is the key to HP.
/ Does HP matter? #52
Yes, exactly...thanks for helpful post. If you have an engine that produces a lot of low end torque and the curve stays fairly linear (or increasing) you can get great times without a lot of shifting. If you have a high reving engine with the poor low RPM torque and produces the torque at 5-7K RPM you have to do a lot of shifting to keep in the power band for good 0-60 runs. Launch control and lightened flywheels can help these get to the power band :)
/ Does HP matter? #53
As far as HP mattering, I might as well mention I have Kohler K341 16 HP engines that have tons more torque than the newer 26+ HP gas twin engines being made. The Kohler K series are little torque monsters. But I digress as we all know the HP games some manufactures have played in confusing the ratings for the consumer.
/ Does HP matter? #54
YOU are right John. HP will make any torque you want -- just run it thru an appropriate gearbox. It is very difficult to soundbyte this issue because the terms become inseparable as soon as you start talking HP transmitted by rotation. Torque is a static - a force at the end of a leverage arm trying to twist around a pivot. There is no work done until there is motion. As soon as there is motion you have the Force times a Distance that the force at the end of the lever moves. Work is being done. Also, inherent in any motion is its speed - so that D component is truly D per unit time. So with motion attributed you have (F X D)/Time. Thats Foot Pounds per second. Thats HORSEPOWER. The fact that the distance is in a circle doesnt matter.
---- Just imagine that circle is a drum on an engine shaft reeling in a rope with a weight on it. For convenient example make the drum 1' in radius. Its circumference is then 2 Pi feet ~ 6.28 ft. Note that the lever is 1foot so engine torque in ft lbs arrives out at the end of the lever as a force in pounds ... 30 ft-lbs gives you 30lb on the drum rim. If that drum rotates once lifting a 30# weight your engine does 6.28 x 30 ~ 189ftlb of work. What HP? ... Well, how fast did the engine do the work? ... Suppose it was running at 1200rpm - thats 20 rps - therefore it produced 189 x 20 ~ 3800 ftlb/sec. I think the conversion is about 550. Looks like about 7HP. :confused3:
larry
/ Does HP matter? #55
larry
I don't even know what to day here, I'm just too tired to get into the the difference between the actual physics and calculations (some erroneous).
But this does have to be addressed "HP will make any torque you want -- just run it thru an appropriate gearbox" I think someone already mentioned that torque is the amount of twisting force and engine can produce. Gearing cannot produce torque but can multiple the torque the engine puts out. HP is a calculation and cannot make torque.
Oh what the **** one more "Torque is static" Torque can be static, but in an engine it is not. There is no torque produced until the engine is running. The torque is produced by the engine transferred to the transmission, to the wheels and to the ground. An example of static torque is the torque of a nut and bolt.
I didn't read the 2nd paragraph so not sure there.
/ Does HP matter? #56
larry
There is nothing erroneous. The problem thruout is in trying to separate torque from HP in a non rigorous fashion. Torque is nothing but a result of leverage. When it overcomes a resistance, causing movement, doing work, it immediately becomes HP. In your example, if the nut turns its HP. [I tried to describe that. ... Do you have a question?]
larry
/ Does HP matter? #57
I am not sure why this is hard for some to understand.
HP is a number that cannot actually be measured. In is simply a calculation based off of torque AND time.
Think of it this way, HP is simply the rate (speed) at which torque can be applied. Therefor HP remains constant. It cannot be increased or decreased (except for frictional losses). Torque CAN be changed with simple gearboxes.
If you can DOUBLE the torque and cut the speed IN HALF with a simple 2:1 gearbox. But the output HP is the SAME, even though the torque changed. Because again, HP is the rate in which the torque can be applied. So you are applying 2x's the torque, but it is taking twice as long.
You can have two motors that are capable of making the same amount of torque, but one can apply it faster, thus has more HP.
Using a drum and cable example, (a winch): it the engines have the same torque, the amout they can pull is going to be the same. BUT, if one of the driving engines has more HP, it can spool up the cable FASTER. But it cannot pull any more if the torque is the same.
/ Does HP matter? #58
I'm glad I deleted my post from yesterday, as I think I was only drawn into a childish battle with an un-armed opponent.
Good to see, at least someone read my post while it was up, and took something away from it.
/ Does HP matter? #59
So far I would have to agree with LD1 on the troll thing. All you've done is call him out and then you say you posted the support of your views and then deleted it. So thus far you have added nothing but friction.
Now I happen to disagree with a couple of opinions in this thread but I try to explain why and so does the person who disagrees with me. I can respect that. You really should do the same and if you have information to help the thread, wouldn't that be something you would do. If you disagree with anything I have posted and if I am in error with my understanding, please enlighten us and share the higher intelligence you seem to be boasting of. It's only fair to offer an alternative notion.
/ Does HP matter? #60
2023 Bobcat T64 (A64126)
2023 Bobcat T64...
2020 KUBOTA KX080-4 EXCAVATOR (A65053)
2020 KUBOTA...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
