Does anyone have a solution for Puncturevine (Tribulus terrestis)?
   / Does anyone have a solution for Puncturevine (Tribulus terrestis)? #41
A "herbicide" license can be handy for RUP (Restricted Use Pesticides) if you need them.
Mississippi issues a Private applicator certification that expires after 5 years. You have to complete an online course (cost $20 last year I think) that took me about 20 hours of Laz-Boy surfing.
(I probably could of done it in 5 hours if I had set up two monitors so I could have looked up things while taking the tests :) ) Basically the course can be summarized as read and follow directions on the label and keep record of using RUP.
Other states handle it differently but may have reciprocity.
Link to MSU course
   / Does anyone have a solution for Puncturevine (Tribulus terrestis)? #42
FWIW, I ran into the applicator licensing issue trying to find the right herbicide to kill kudzu, but found an ag research expert who recommend using two unrestricted herbicides in combination with one another that is working much better for me.
It may be that similar research has been done on killing puncturevine with some combination of unrestricted herbicides?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 Big Tex 10PI...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
International 454 Tractor (A59814)
International 454...
