Does anybody know of any cheaper alternatives for Kioti relays?
   / Does anybody know of any cheaper alternatives for Kioti relays? #1
MinnesotaEric
Super Member
Nevis, MN
Kioti NX6010
Back before the dead internet when a guy could readily find things, this was easier to puzzle out. Now with the truncated search results I'm having trouble identifying less expensive alternatives for the 4-pin 70A T4180-69951 and 5-pin T4180-69961 which hang out under the hood, as well as the 5-pin 20A T4180-69941 relays that populate the fuse box.
   / Does anybody know of any cheaper alternatives for Kioti relays? #3
Quick search shows the 951 at Walmart for under $10, the 961 on ebay for $8 and change. No luck on the other, but might check Digi-Key or similar. I'm sure someone's already posted a link.
   / Does anybody know of any cheaper alternatives for Kioti relays? #4
As I suspected, it turns out that Kioti uses standard relays. The only weird things are:
1) Under the hood the tab is on the opposite side of the relays I have so a guy will need to twist the harness to plug in the socket.
2) While using standard relay sockets for a automotive 5-pin and square 4-pin, the OEM relays are slightly smaller than standard. This matters in the fuse box because the relays are jam-packed in tightly.
All to say I have NOT found a replacement for the 69941 20A 5-pin fuse box relay.
But for the 69951 70A, a cheap 4-pin normally open relay will work. Amazon.com: EHDIS 4-Pin Relay 12V 80A Automotive Car Relay On/Off Normally Open Car Truck Boat SPST Relays High Power Model JD2912-1H-12VDC 80A 14VDC [2 Pack] : Automotive
And for the 6996130/20A 5-pin, just get any 5-pin that is normally closed on the 87a pin that switches to the 87 pin when energized.
   / Does anybody know of any cheaper alternatives for Kioti relays? #6
When companies divert from a common, standard, reasonably price product so you have to purchase from them at a stupid overinflated price that really pizzes me off. Good thing there's people around that don't mind making a few changes to save some $$$. Sorry, the fact that a person has to jump thru hoops annoys me....in case it's not obvious LOL.
The OEM T4180-69941 relays that were manufactured by OMRON are 25.7mm square, so I called Digikey to find an equivalent. Talking with a tech, I powered the OEM T4180-69941 relay switching hot and ground on pins 85 and 86 thereby confirming that the OEM relay does not have a diode, and the Digikey tech determined that Digikey part number 3385-AZ9731-1C-12DC3R1-ND should be a proper replacement. FWIW, the Kioti T4180-69961 is the same relay except it has a tab and Digikey has that option as well.
If you look at the Data Sheet of of the following link, you can see the variants of the relay.
I ordered 14 relays and got to pay an additional $8.65 in tariffs because apparently American Zettler who makes the Digikey-sourced relays must manufacture them in China.
For the record, the Zettler relays ordered through Digikey are ever-so-slightly smaller than the OEM T4180-69941 relays and so they will fit just fine in Kioti's fuse box as a replacement. The Internet can thank me later.
   / Does anybody know of any cheaper alternatives for Kioti relays? #8
14 relays….man your blowing alot of relays. In 14 years ive replaced 3.
And those were the twin relays that run wipers, plus one that ran the pto
I use standard 5-pin relays in a variety of things other than Kioti tractors and at $2.80 each plus tax, shipping and tariff, the price was right.
   / Does anybody know of any cheaper alternatives for Kioti relays? #10
I thought about getting some on amazon, but chickened out and bought from Kioti. Have 4 spares. 2 regular and 2 twin relays
2000 KENWORTH W900 (A55745)
2000 KENWORTH W900...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2017 TROXEL 150...
