Does 29hp Kawasaki DFI Watercooled have problems
/ Does 29hp Kawasaki DFI Watercooled have problems #1
Mike_S
South of Kansas City
JD4400HST
As in an earlier posting, this engine has a serious problem in that after using the Toro ZMaster which it powers is used for mowing for about 45 minutes, the fuel filter empties of fuel and the engine dies. Let it sit for 5-15 minutes (depending upon its mood) and it starts back up as good as new and then that repeats all day long. The fuel tank selector valve and fuel pump have been replaced. I have tried leaving the fuel tank caps loose as well as extra tight and the dying issue also happens with both tanks. This problem started at 52 hours on the hour meter, the dealer needs 2-3 weeks of wait time until they can get to it and another possible week to get parts if they can figure out what parts.
I contacted Kawasaki customer service for that line of engines and was told, apologetically, that they could not help me due to contractual obligations with Toro.
I am wondering if the 29hp Kaw water-cooled DFI engine is generally a trouble-prone engine or has a history of having a particular issue and is otherwise dependable -- the downtime is a killer and dependability is needed and I need to decide if I need to trade it for a different brand.
Thoughts, opinions, experiences with this engine since it is used on several brands of ZTR's besides Toros?
Thanks,
MikeSp
/ Does 29hp Kawasaki DFI Watercooled have problems #2
Mike, we have a JD797 with the same engine. 1800 hour and no fuel problems. the only major problem with the motor is when the ACR contraption on the cam came apart and took out the govenor gear. Replaced the cam, govenor and waterpump while we were in there. DFI has an electric fuel pump that supplies the fuel to the fuel injectors. Is the fuel pump still running when the engine stalls? Have you blown back through the lines going into the tank? On our JD there is a little screen on the end of the suction line that goes in the tank. Thankfully our JD only has one tank to worry about.:D You could always setup a nurse tank too and see if runs for a while with out starving for fuel.
/ Does 29hp Kawasaki DFI Watercooled have problems #3
Just read your op. Did you change the air filter right before it happened? just curious.
At 52 hours and not mowing in dusty conditions, I have had no reason to change the air filter... yet.
Mike
The fuel pump shuts down when the engine stalls (remember that it has been replaced). When the key is turned to the "prime the pump" position, the pump whines as usual and fills up the fuel filter -- but when the engine is starved for fuel, the fuel pump is HOT and even though the fuel pump fills the fuel filter, the fuel empties immpediately--usually bubbling as though it were boiling. Ten minutes later, the fuel pump will fill the fuel filter and it will start up and fun fine. I cannot help but wonder if it is the DFI controller that is having a senior moment--even at 52 hours.
Thanks for your observations -- will blow back the lines, but it is pretty unlikely as careful as I am about fueling both tanks that both tanks would be clogged and act in the same manner (but not impossible).
Mike
Shot gun--just curious, have you used ethanol-blended gasoline in your JD797 with that same Kaw engine? I ask because it ran great last year and starting January 1st of this year, Missouri became the third state to require 10% ethanol content of ALL unleaded fuels and I am thinking that my engine may be having a good ole case of vaporlock (takes me back to cars I owned in the 1960's...YIKES!!!) It is too coincidental that the fuel problems started with the first fueling of 10% ethanol blend (which I did not know since the law does not require such blending be posted...grrrr)
I am wondering if ethanol blends will vaporlock easier than straight gasoline.
Mike
/ Does 29hp Kawasaki DFI Watercooled have problems #7
Yes the gas we get here is blended. I'm not sure what the % is. As far as being careful on filling the tank thats not what I'm woried about. New tanks if they arnen't carefully cleaned at the factory you end up with plastic shards that get sucked up and stick to the intake screen. I checked our fuel pump after it runs a while you can't touch it. It's pretty warm. It sounds like there is a sensor problem telling the fuel pump to shut down. I didn't see any thermal switch to shut off the fuel pump. I guess vapor lock is possible... where is the fuel pump located on the machine?
Does the machine start right back up after it stalls? I was thinking you could instead of blowing back through the lines pull them out of the tank and check the ends of the lines for stuff. I'm pretty sure they use top draw on them.
On the air filter I was thinking that if you switched it maybey you got the wrong one but i thought about it that was only for the carb units and the new machines all use HD donaldson filters
The fuel pump is located just to the left of the seat behind the fuel filter and fuel tank selector valve -- easy to see and easy to get to.
The engine will not start up immediately after a stall -- the fuel pump attempt to fill the filter, but the filter empties as fast as the fuel enters it. After a 10 minute wait, it starts immediately and runs fine for another 30-45 minutes.
It sounds like a good idea to check for the plastic shards (sometimes such things are NOT cleaned out like the aluminum millings that were left in the transmission housing of my first JD 4400HST tractor which destroyed the hydraulics, hydrostatic tranny, brakes, etc.).
It is interesting that you are using blended gasoline. I found a Toro "Master" service center today that was glad to chase down the problem even though I did not purchase the ZTR from them -- eventually they ended up with some conversations not only with Toro tech support wondering about the blended fuel and vaporlock but Kawasaki stating that mine was the 6th such incident with that engine and that they were sending out a new fuel pump that was designed to solve the problem of vaporlock -- that the fix was a Kawasaki engine part number and not a Toro part number. At least there is now hope!!
Thanks for your suggestions,
Mike
/ Does 29hp Kawasaki DFI Watercooled have problems #9
Good deal! We've had our since april 2003 with no fuel problems. It sounds like you've got it under control now good luck.
/ Does 29hp Kawasaki DFI Watercooled have problems #10
Mike
This is an obvious clue. A good test would have been to use freon, co2 or water to cool the pump and see it it "cured" the problem.
Sounds like your nightmare is almost over.
/ Does 29hp Kawasaki DFI Watercooled have problems #11
I'm sure you are having vapor lock problems. No reason for the fuel pump to normally get hot to the touch. Is the pump picking up heat from the motor in some way. I'm guessing the replacement fuel pump will be mounted on stand offs to space it away from whatever is generating the heat.
The electric fuel pump is located beside the seat and not even close to the engine -- I have a gut feeling that the vapor lock has something to do with the new alcohol-blended fuels AND the digital fuel injection and am awaiting the arrival of the Kawasaki pump.
I suspect that as long as fuel is passing through the fuel pump, it remains warm, but when it is deprived of fuel, it overheats (just a guess).
Hopefully, the new pump will arrive today.
Mike
/ Does 29hp Kawasaki DFI Watercooled have problems #13
Keep us updated please. Just incase I have a problem in the future it would be nice to refrence.
/ Does 29hp Kawasaki DFI Watercooled have problems #14
Mike Any news on your machine?
I gave up on my local sales/service center since they didn't seem to care once I bought a commercial machine from them, so in desperation, stopped by a "Master Service" center for Toro that was a half-hour away and they immediately took a serious interest, called Toro and Kawasaki and found out that YES, there was a problem with the fuel pumps on the water-cooled Kawasaki engines with digital fuel injection--vapor lock was an issue with the new alcohol blended fuels. Kawasaki stated that the solution was to use their fuel pump and not the Toro fuel pump (Toro part number). The new pump was received by the service center a few days later, but my timing was an issue -- the new Toro dealer (new to me, but has been in business many years) is going on vacation next week.
The new pump does not bolt on the same way nor does it have the same electrical connector as the Toro OEM pump, so the service center will pick up my mower and between them, Toro and Kawasaki, will figure out how to mount the new pump.
Kudos to this other Toro dealer that took a serious interest in my warranty problem even though I did not purchase the machine from him. It turned out that mine was not the only Kaw 29 hp engine out there with that problem and all my local dealer had to do was make a couple of phonecalls.
Hopefully, in abou a week, it will be running right thanks to a dealer that actually cared--will post when it gets fixed.
Mike
/ Does 29hp Kawasaki DFI Watercooled have problems #16
Thanks! and if you can will you post a pic of the new pump? Just curious if it looks like mine or not.
The Toro Master Service center owner personally picked up my ZMaster 589 and installed the new Kawasaki fuel pump and delivered it today. Although the grass was tall and wet, I mowed three acres and it did not die once, thus I feel that the problem was solved. I have never posted a picture on this forum, so will give it a try. Many thanks to Curtis Arnold whose efforts solved the vaporlock problem even though I did not purchase the mower from him -- he gets my business next time (he earned it unlike the local dealer).
Mike
/ Does 29hp Kawasaki DFI Watercooled have problems #18
Thanks Mike. That looks like the one I have already? I'll keep an eye on it.
Thanks for sharing.
2019 CATERPILLAR 950M WHEEL LOADER (A60429)
2019 CATERPILLAR...
Gravely ZT 1540 40in Zero Turn Commercial Mower (A59228)
Gravely ZT 1540...
Informational Lot - Shipping (A61307)
Informational Lot...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
