Dodge Cummins Engine Concern
/ Dodge Cummins Engine Concern #161
Does that 1987 have disc rear brakes? I bet not. If it does, you're just plain lucky.
My 2004 GMC seizes up the rear calipers readily if not looked after. Salt damage is LOTS more prevalent in rear calipers than front.
Haha! Good point... Rear drums. Duh! Lol!
/ Dodge Cummins Engine Concern #164
My 1991 Silverado had to have several of the brake lines, the gas line and the gas tank replaced due to rust. I eventually traded it in when the rocker panels under the extended cab area rusted through. Wouldn't pass inspection, wasn't worth fixing. Got a 2004 Silverado, Z71, 4x4. Yeah, I know, but the price was right. Replaced one brake line due to rust. About a year later, another one rusted through when my BIL was driving it. I had to replace that brake line and my BIL's underwear. No one hurt when the brake pedal went to the floor and he had to use the emergency brake to stop. I finally had all the brake lines replaced with stainless steel ones.
/ Dodge Cummins Engine Concern #165
My '04 Sierra has only 60,000 miles. I have replaced all the brake lines, all the fuel lines (at the same time when the first brake line failed) and the rear bumper due to rust. My rocker panels & cab corners are solid due to front mudflaps from day 1. I'm committed to keeping this truck as I'm not ready to be without a truck, but it is no longer my daily driver for spring, summer & fall. I recently bought a Mini Cooper S hatchback which is infinitely more fun to drive.
/ Dodge Cummins Engine Concern #166
/ Dodge Cummins Engine Concern #167
I own a Dodge like the OP is looking at....overall great truck.
On the battery subject, I am convinced that heat kills batteries faster than cold.
For me, the most we get is 3 years. Only exception was a Toyota FJ40 that lasted 7 years.
Two batteries in parallel is a crap shoot.
/ Dodge Cummins Engine Concern #169
I own a 2005 2500 Cummins. I only have 36 k on mine and can tell you that mine really didn't break in until 30 k. I went from a solid 19 mpg to 22 mpg right after I turned 30 k. I think a full fluid swap is a good idea along with belt and hoses. I did have the rotors on my truck rot at the edges and tear up the pads and I definitely attribute that to it not being driven. I would also recommend removing the tires especially if you have the aluminum rims and coat the back of the rims with anti seize. I had a **** of a time getting mine of the rotors. I would also change the fuel filter frequently and run Diesel Kleen or some other treatment the first couple of tank fulls Every vehicle I ever owned I usually drove a lot, but I have a company vehicle that I drive to work and its kept the mileage low on my truck. I bought a Dodge because a former employer ran them and didn't maintain them and still got 300k out of them. good luck with it !!!
I probably need to join some truck forum but will ask here as this is less truck and more Cummins engine related and diesel engine to some degree is diesel engine.
I have been looking at, for some time an upgrade to my tow vehicle for moving my equipment.
I most likely will have the opportunity to purchase a 2006 Dodge Ram 3/4 ton truck shortly. Without going into TMI of the personal details of the owner it is a 2006 with a little over 17K miles. Most of that was prior to 3 years ago and in the last three years has had even less with it being driven on Sundays mostly. (no jokes about the grandma car only being driven to church on Sundays)
While I really was looking for a 1 ton for more flexibility I think the 3/4 will do what I need.
My question/concern is:
At 17.1K the engine is barley broken in and after that little use in 8 years and especially in the last 3 years how much/many problems might I be looking at with an engine that has basically been rotting on the vine?
If I get it, it will have a full fluid swap and fuel filter change immediately unless I find evidence that it has been done very recently.
Well it is "a sad day in Mudville" for those that are old enough to understand the phrase.
The owner decided to sell it to a family friend of her father's (it was his truck, rip) and not to her friend, my wife. As a result I will not get the truck. :( Not happy, disappointed, all that, but, oh well.
Since the owner had been thinking about whether or not she would sell it for months I had put off looking elsewhere as I thought this was a deal worth waiting for.
Now I can look elsewhere without thinking that I missed a deal. I know I missed it, there is no thinking that I might.
/ Dodge Cummins Engine Concern #171
/ Dodge Cummins Engine Concern #173
Well it is "a sad day in Mudville" for those that are old enough to understand the phrase. The owner decided to sell it to a family friend of her father's (it was his truck, rip) and not to her friend, my wife. As a result I will not get the truck. :( Not happy, disappointed, all that, but, oh well. Since the owner had been thinking about whether or not she would sell it for months I had put off looking elsewhere as I thought this was a deal worth waiting for. Now I can look elsewhere without thinking that I missed a deal. I know I missed it, there is no thinking that I might.
That's too bad but if you are patient there are other good deals out there.
/ Dodge Cummins Engine Concern #174
No self discharge problem with series hookup. 2 big 6V would be superior.
That must be why every tractor manufacturer quit using 6 volt batteries in series in the 1980's and the owners of earlier tractors using batteries in series have been reconfiguring cables and converting to parallel setups ever since. Not much to debate, so I won' t comment further.
/ Dodge Cummins Engine Concern #175
That's a bummer. On the good side you learned a little bit about Cummins trucks.
/ Dodge Cummins Engine Concern #176
So what is the reason? Space considerations preventing a large single battery that would essentially be 2 series 6s. The 6V battery is being supported in less and less variety.
,,,.Youre right ... Theres no debate that a larger number of cells [12 vs 6 cells] presents a higher number of potential failure points. And one weak cell in a // system takes down both batts.
/ Dodge Cummins Engine Concern #177
Wether you have two 6v batteries or one 12 v battery, you have the same number of cells.
/ Dodge Cummins Engine Concern #178
Yes. The issue is connecting 2 12s in // to get the grunt of 2 comparable sized 6s in series.
/ Dodge Cummins Engine Concern #180
One bad cell in a series system results in an immediate no start. Simply not the case with a parallel system.
Read this thread:
Viewing a thread - Two 12 v batteries vs two sixes volt series&highlightmode=1#M3732771
And I admit to a mistake; IH abandoned 6V batteries in series in the late 1970's.
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
JOHN DEERE 702 - 8 WHEEL V-RAKE (A64278)
JOHN DEERE 702 - 8...
2016 Komatsu WA320-8 Articulated Wheel Loader (A64553)
2016 Komatsu...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2015 Hyundai Elantra Passenger Car, VIN # 5NPDH4AE7FH560718 (A64557)
2015 Hyundai...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
