Do you think these are interchangeable?
/ Do you think these are interchangeable? #1
CajunRider
Platinum Member
Cajun Land
Kioti DK45
The steering hydraulic cylinder for my DK 45 is listed for $480.95 by Kioti parts as: Parts Finder Haltom Equipment, Inc. Mooresville, IN (317) 831-4985
I can get it at TractorJoe for $398.62.
However, the same part number was listed for TroyBilt, MTD, and Cub Cadet for much less.
For example: Cub Cadet 8454 (54AX85-71, 54AJ85-1, 54AV85-1, 54AX85-1, 54AJ85-71) - Cub Cadet Tractor Steering Cylinder Group Diagram and Parts List | PartsTree.com
My thinking is that these are just hydraulic cylinders and not internal machinery parts and I need two. The saving is around $300 total. Is it worth a try?
Thank you guys!
/ Do you think these are interchangeable? #5
Looks like they have the EXACT same part number!
Since the connector on my old steering cylinder is an old style I have to order a new pin and nut for the new cylinder. I'm hoping to get it installed this weekend. I may not get to try it though. My tractor won't start. It will turn over and runs for 3 sec then die. I think I may have some issue with the fuel system.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
2018 PETERBILT 520 6X4 T/A GARBAGE TRUCK (A66091)
2018 PETERBILT 520...
Case 1150G Crawler Dozer (A66285)
Case 1150G Crawler...
King Kutter II Tiller for sale.
King Kutter II...
