Do you think these are interchangeable?
/ Do you think these are interchangeable? #1
CajunRider
Platinum Member
Cajun Land
Kioti DK45
The steering hydraulic cylinder for my DK 45 is listed for $480.95 by Kioti parts as: Parts Finder Haltom Equipment, Inc. Mooresville, IN (317) 831-4985
I can get it at TractorJoe for $398.62.
However, the same part number was listed for TroyBilt, MTD, and Cub Cadet for much less.
For example: Cub Cadet 8454 (54AX85-71, 54AJ85-1, 54AV85-1, 54AX85-1, 54AJ85-71) - Cub Cadet Tractor Steering Cylinder Group Diagram and Parts List | PartsTree.com
My thinking is that these are just hydraulic cylinders and not internal machinery parts and I need two. The saving is around $300 total. Is it worth a try?
Thank you guys!
/ Do you think these are interchangeable? #5
Looks like they have the EXACT same part number!
Since the connector on my old steering cylinder is an old style I have to order a new pin and nut for the new cylinder. I'm hoping to get it installed this weekend. I may not get to try it though. My tractor won't start. It will turn over and runs for 3 sec then die. I think I may have some issue with the fuel system.
(INOP) 2022 POLARIS RANGER 500EFI RTV (A64280)
(INOP) 2022...
2021 Gatormade Lowboy Trailer (A62613)
2021 Gatormade...
Sakai SW354 (A64126)
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
