Do you think these are interchangeable?
/ Do you think these are interchangeable? #1
CajunRider
Cajun Land
Kioti DK45
The steering hydraulic cylinder for my DK 45 is listed for $480.95 by Kioti parts as: Parts Finder Haltom Equipment, Inc. Mooresville, IN (317) 831-4985
I can get it at TractorJoe for $398.62.
However, the same part number was listed for TroyBilt, MTD, and Cub Cadet for much less.
For example: Cub Cadet 8454 (54AX85-71, 54AJ85-1, 54AV85-1, 54AX85-1, 54AJ85-71) - Cub Cadet Tractor Steering Cylinder Group Diagram and Parts List | PartsTree.com
My thinking is that these are just hydraulic cylinders and not internal machinery parts and I need two. The saving is around $300 total. Is it worth a try?
Thank you guys!
/ Do you think these are interchangeable? #5
Looks like they have the EXACT same part number!
Since the connector on my old steering cylinder is an old style I have to order a new pin and nut for the new cylinder. I'm hoping to get it installed this weekend. I may not get to try it though. My tractor won't start. It will turn over and runs for 3 sec then die. I think I may have some issue with the fuel system.
1968 MTTI Lowboy Trailer (A62613)
1968 MTTI Lowboy...
2008 Ford Expedition SUV (A61574)
2008 Ford...
SUKUP 4R30" HI-SPEED SHIELDED CULTIVATOR (A64276)
SUKUP 4R30"...
Tennant M30 (A64127)
Woodland Mills Sawmill (A65579)
Woodland Mills...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
