Do yanmars have a "float"?
/ Do yanmars have a "float"? #1
Cord
Richfield, Wi
Resident Architect
Do yanmars have a \"float\"?
I have a little 1110. Is there a way to set the 3pt hich so it "floats"? You know, where the arms would follow the changing grade with out input.
/ Do yanmars have a "float"? #2
Re: Do yanmars have a \"float\"?
In a sense, almost all 3pt hitches "float". Unless you have one of the very few tractors which provide down pressure on the 3pt hitch, then any upward change in grade just behind the rear wheels will cause the implement to rise relative to the tractor. You can prove this simply by lowering the 3pt all the way (with no implement attached), and lifting up on the lower 3pt arms by hand. They should rise relatively easily, with the weight of the arms the only resistance. By the way, no Yanmar tractor that I know of has down pressure. It would be a bad idea for any small tractor that is traction limited such as our Yanmars because the net result of down pressure is to reduce the weight on the wheels, thus reducing traction.
Many farm tractors provide true float for ground engagement - primarily plowing with a moldboard or "turning" plow on the 3pt. The float function automatically raises the implement in response to an increase in required pull. The idea is to keep the tractor from stalling when you hit a patch of "tougher" soil that is harder to plow by raising the plow just enough to reduce the required pull. When the required pulling power is reduced, the plow returns to the set depth. The old 8N I used as a kid had this float feature - though I was never sure it actually worked.
I hope this explanation is clear enough. I sure is long enough!
Thanks Greg. The only time my arms will move up is when the engine is off. Otherwise they are locked in place. I'm thinking it might be controlled with one of the valves below the seat, but which one?
Well, I fiddled with the valves last night. Looks like the one valve facing sideways controls the rate of bleed. I can't recall what the second one facing forward does. Apparently, if I set the bleed rate to a generous amount and leave the lever in the down position, the arms will then float.
/ Do yanmars have a "float"? #5
The forward facing one is used to lock an implement in the up position for transport. The arms should move up from a lowered position freely regardless of the position of these two valves. The 3pt piston is not attached to the rock shaft at all. There is a rod connected to the rock shaft that the piston pushes on, but the rockshaft and rod should move easily from the lowered postion to a higher position.
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
Kubota SVL95.2s Skid Steer (A62613)
Kubota SVL95.2s...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2017 Hyundai Trailer (A62613)
2017 Hyundai...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
