newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,884
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
Get a tractor with a backhoe then drive with the stabilzers down.
Yep. See Gradient, Slope, Grade, Pitch, Rise Over Run Ratio Calculator for a calculator that shows the angles. Entering a 100' rise and a 830' run gives ~12% grade or about a 7 degree slope. Most tractors should be able to handle that
Aaron Z
Since you are new to tractors, you might want to go rent one for a weekend to get an idea of the capabilities of a particular size/type of machine to use as a baseline for comparison.
+If all you want to do is move dirt, then a skidster (Bobcat) is the way to go but it is designed to do just that and other chores while possible are not as easy as a tractor. It doesn't have a 3 PH to use conventional attachments but they do make skidsteer attachments for just about all the things a normal tractor uses, they are just 4 times the price and rarely can you find good used farm type equipment for a skidsteer.My mistake. I was trying to figure out if I need a full size tractor or will one of the little "bobcat" type things be better suited to the job. Is a smaller lower to the ground more stable? I have seen them doing road work so I assume it will have the power.
As for the shovel, I just celebrated the 56th anniversary of my 9th birthday. I refuse to grow any older than 9! So forget the shovel thing for bigger jobs.
Please post pics of your property if you can. Especially pics of your 'billy goat' hill because I think that is the part you want to terrace. That's the part I was recommending the dozer for.Duh! Now why didn't I think of that? I like the idea of a test drive. I mean I do it before I buy a car. This is such a great site and my thanks to all of you.
You absolutely do NOT need a tractor, BUT I could use a second one so if you're game I'll show you how to operate the one you buy and when I'm done doing the work you need done I'll just disappear into the wind with my new tractor and you still won't need one! :dance1:
It's a deal one needs to entertain!
From some brief reading here, i would consider a tracked skidsteer. if all your doing is moving dirt and such and possibly some mowing go with a highflow tracked unit. They are unbelievably stable on steep slopes.
Personally, i have been on a tractor for 53 years now in all sorts of foolish places, i cant say i have been scared of situations but i show respect for the machines capabilities and will push it to the limit and then some, Its all right to be scared to operate a piece of equipment on a slope, it is dangerous work for a new comer, a lot to take in and understand, go slow and start on some level ground to start out. Soon it will come natural just like when you learned to walk.
If in doubt then the best thing is to rent a certain piece of equipment for a weekend and try it, dont forget the insurance on it in case it does roll .. . Becareful and good luck, John
BTW ( 3 years ago i rolled a Barko log loader over the side of a mountain it stopped 300' down on a ledge when the ground gave way, i havent regained the nerve to operate one since and i operated one of these for 30 years)
