Do I need a CDL?
/ Do I need a CDL? #81
Duffster and Storm56
here is the Pennsylvania DMV regulation
What Class of Driver's License Do You Need?
In Pennsylvania, driver痴 licenses are issued specifically for the class and type of vehicle you operate. Therefore, the class of driver痴 license you should have depends specifically upon the type of vehicle you operate. Generally speaking, the majority of applicants for a Pennsylvania driver痴 license will be operators of regular passenger vehicles, pick-up trucks or vans.
Classes of Driver's Licenses
Non-commercial Driver's Licenses
  • CLASS A (minimum age 18): Required to operate any combination of vehicles with a gross weight rating of 26,001 pounds or more, where the vehicle(s) being towed is/are in excess of 10,000 pounds. Example: Recreational Vehicle, when the towing vehicle is rated at 11,000 pounds and the vehicle towed is rated at 15,500 pounds (total combination weight of 26,500 pounds).
  • CLASS B (minimum age 18): Required to operate any single vehicle rated in excess of 26,000 pounds. Example: Motor homes rated at 26,001 pounds or more.
  • CLASS C (minimum age 16): A Class C driver痴 license will be issued to persons 16 years of age or older, who have demonstrated their qualifications to operate any vehicles, except those requiring a Class M qualification, and who do not meet the definitions of Class A or Class B. Any firefighter or member of a rescue or emergency squad who is the holder of a Class C driver痴 license and who has a certificate of authorization from a fire chief or head of the rescue or emergency squad will be authorized to operate any fire or emergency vehicle registered to that fire department, rescue or emergency squad or municipality(emergency use only). The holder of a Class C license is authorized to drive a motor-driven cycle with an automatic transmission and cylinder capacity of 50 CCs or less or a 3-wheeled motorcycle with an enclosed cab.
  • CLASS M (minimum age 16): A Class M driver痴 license will be issued to those persons 16 years of age or older who have demonstrated their ability to operate a motorcycle or motor-driven cycle. If a person is qualified to operate only a motorcycle or motor-driven cycle, he/she will be issued a Class M driver痴 license. If you test on a motor-driven cycle, an "8" restriction will appear on your driver痴 license. This restriction prohibits you from operating a motorcycle. If you test on a 3-wheeled motorcycle, a "9" restriction will appear on your driver痴 license. This restriction prohibits you from operating a 2-wheeled motorcycle. Pennsylvania Motorcycle Operator痴 Manual (PUB 147) or the Mopeds, Motor-Driver Cycles and Motorcycles Fact Sheet located on PennDOT痴 Driver and Vehicle Services website in the Motorcycle Information Center.
PennDOT Driver and Vehicle Services - Classes of Licenses
Class A license here it is in black and white (or red in this case) Recreational Vehicle, when the towing vehicle is rated at 11,000 pounds and the vehicle towed is rated at 15,500 pounds (total combination weight of 26,500 pounds)
now a RV
Class B licensee Motor homes rated at 26,001 pounds or more.
tom
What is the CGVWR of the truck and trailer you drive?
/ Do I need a CDL? #82
Usually the only time you don't need a CDL if you are over 26k is if you are a farmer doing farm business within 150 miles of your farm. That motorhome example was over 26k so you would need a CDL.
/ Do I need a CDL? #83
My local trooper told me trailers over10k require a combination license & if the combo breaks 26k cdl is in your future.also DOT regs in effect when crossing state lines ,ie Maryland from Pa:confused2:
/ Do I need a CDL? #84
You only need a CDL if used in commerce. The example was showing it would need a NON commercial class B because it was over 26k.
/ Do I need a CDL? #85
What's his idea of a combination license? :confused2:
/ Do I need a CDL? #87
new truck is a dodge 5500 around 18,000 lbs trailer 14,000= 32,000
the old one wad a f450 that was about 14,000lbs
tom
That makes sense then. The way you worded it before made it sound like you needed a class A solely because the trailer was over 10k.
/ Do I need a CDL? #88
The way i understand it ,in PA a combo license adds truck gross wt + trailer gross wt[ 11,000 gvw tk + 14,000 gvw trl = 25,000 gvw license fee for tk] +14,000 gvw trl license fee. not cdl but dot :confused2: If it totals over 26001 then cdl is needed. unless of course u find a loophole!!Also if your tk doesn'thave combo wt on PA title u need manufacturer proof of tow capacity to get it . that was enough to change my mind from a gn trailer to a 9990 bumper pull:confused: don't know how true just what different troopers and notaries told me
/ Do I need a CDL? #89
Be careful crossing state lines. Don't a$$ume all states are the same.
I have a class A CDL here in NC. In my state of NC, I can travel within NC(intrastate travel) with just a medical card thats renewed every 2 years.
If I plan to travel to another state, I'm required to have a DOT number on my truck, keep up with a log book, carry insurance minimums (I think $500K), random drug test and a few more things.
Let's just say, I don't travel outside of NC.:laughing:
/ Do I need a CDL? #90
ALKY
That would require a non cdl class A look at post 37 right from PA DMV if non commercial.
tom
/ Do I need a CDL? #91
To come full circle to the original posters question:
His truck GVWR is less than 10k
His trailer GVWR is 14k
The combined weight does not exceed 24k
If his bobcat and the balance of the equipment is his private property and not used in a commercial setting, he will not need a medical, commercial plates or insurance and will be legal to tow federally provided no vehicle limitations are being exceeded.
A very similar situation would be him and his family in the truck towing a 5th wheel camper that weighed 15k.
Now as soon as the bobcat, truck and trailer are being used commercially (for reward) even if only transporting someone else's equipment from 1 place to another, then it is a commercial operation and all the rules start applying. Truck is below 10k so a chauffeur's license is not required for that, BUT since the GCVWR is 24k he would need a chauffeur's license in that configuration. The Chauffeurs license requires a medical, so there is that too.
The wording on the exemptions is a bit vague and I think that is the key problem in obtaining answers from someone other than a judge.
Going to the federal regulations, things are a lot clearer.
Part 390.3: General applicability. - Federal Motor Carrier Safety Administration
Quote:
(f)Exceptions. Unless otherwise specifically provided, the rules in this subchapter do not apply to
(f)(1)All school bus operations as defined in ァ390.5;
(f)(2) Transportation performed by the Federal government, a State, or any political subdivision of a State, or an agency established under a compact between States that has been approved by the Congress of the United States;
(f)(3) The occasional transportation of personal property by individuals not for compensation nor in the furtherance of a commercial enterprise;
(f)(4) The transportation of human corpses or sick and injured persons;
(f)(5) The operation of fire trucks and rescue vehicles while involved in emergency and related operations;
(f)(6)The operation of commercial motor vehicles designed or used to transport between 9 and 15 passengers (including the driver), not for direct compensation, provided the vehicle does not otherwise meet the definition of a commercial motor vehicle, except that motor carriers operating such vehicles are required to comply with ァァ390.15, 390.19, and 390.21(a) and (b)(2).
(f)(7) Either a driver of a commercial motor vehicle used primarily in the transportation of propane winter heating fuel or a driver of a motor vehicle used to respond to a pipeline emergency, if such regulations would prevent the driver from responding to an emergency condition requiring immediate response as defined in ァ390.5.
In addition, the federal definition of a CMV (commercial motor vehicle) is found here:
Part 383.5: Definitions. - Federal Motor Carrier Safety Administration
Quote:
"Commercial motor vehicle (CMV) means a motor vehicle or combination of motor vehicles used in commerce to transport passengers or property if the motor vehicle
(a) Has a gross combination weight rating of 11,794 kilograms or more (26,001 pounds or more) inclusive of a towed unit(s) with a gross vehicle weight rating of more than 4,536 kilograms (10,000 pounds); or
(b) Has a gross vehicle weight rating of 11,794 or more kilograms (26,001 pounds or more); or
(c) Is designed to transport 16 or more passengers, including the driver; or
(d) Is of any size and is used in the transportation of hazardous materials as defined in this section."
Clearly a combination vehicle not carrying hazardous material and less than 26k and not being used commercially does not fit any of the above descriptions.
In my opinion, the fault for the confusion has been the expansion by states of the Chauffeurs license in an arbitrary fashion (above 10k gvwr) and wording of the exclusions in the chauffeurs license in a manner not consistent with the directive of the feds. The federal regulation makes no distinctions regarding vehicle or trailer weights around the 10k mark and specifically exempts private transport as long as it stays below 26k single or combined. This is the kind of crVp that keeps lawyers employed and innocent people in courtrooms.. Welcome to federal government, where if the law is not screwed up in DC there are many more chances to screw it up in each state.
I hope somebody can help me with this. I live In Pa, and was looking at getting a gooseneck to pull my bobcat. My truck GVW is 9,200 and unladen weight of truck is 6,249. The trailer I was looking at is a GVW of 14,000 and unladen weight of 5,200. My bobcat is around 6,600. Do I need to have a CDL to be legal?
/ Do I need a CDL? #93
To the best of my knowledge PA doesn't have "Chauffers licenses". That is a MI (and IN?) thing.
