DO I NEED A BRACKET FOR FRONT WEIGHTS
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #1
KEYBEAR
Indiana
John Deere X-758
I need a little weight on the front of my X-758 . Thinking some suitcase weights would be the best fast on fast off . Do I need any kind of bracket or is the one already on the tractor used for the weights .
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #2
Yes, That front bracket is the weight bracket.
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #3
Fill front tires with either windshield wiper fluid, or better, the rim guard beet juice. See if that is enough weight.
Thanks I could not find any info in the manual or on line . I would fill the front tires but I only need the weight two or three times when I use the bagger . If I Vac grass it gets heavy and the front gets lite the rest of the time no need for weight .
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #5
The front bracket will hold 4 weights, if you need more there is a 9 weight bracket available from JD which also doubles as a heavy duty front bumper.
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #6
Picked up a weight (40#) at Dealer this morning.. $59
I have been buying weights all winter when I see them at a good price off some local sites .
I have 7 now the low I gave was 25 bucks and the most is 40.00 they need paint but that is cheap .
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #8
Four of the 42 lb. suitcase weights will be all you will need to offset the bagger.
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2022 EZ-GO ELITE...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
250 gal Livestock Lick Tank (A66408)
250 gal Livestock...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2018 DODGE RAM 2500 (A65643)
2018 DODGE RAM...
