DO I NEED A BRACKET FOR FRONT WEIGHTS
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #1
KEYBEAR
Indiana
John Deere X-758
I need a little weight on the front of my X-758 . Thinking some suitcase weights would be the best fast on fast off . Do I need any kind of bracket or is the one already on the tractor used for the weights .
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #2
Yes, That front bracket is the weight bracket.
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #3
Fill front tires with either windshield wiper fluid, or better, the rim guard beet juice. See if that is enough weight.
Thanks I could not find any info in the manual or on line . I would fill the front tires but I only need the weight two or three times when I use the bagger . If I Vac grass it gets heavy and the front gets lite the rest of the time no need for weight .
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #5
The front bracket will hold 4 weights, if you need more there is a 9 weight bracket available from JD which also doubles as a heavy duty front bumper.
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #6
Picked up a weight (40#) at Dealer this morning.. $59
I have been buying weights all winter when I see them at a good price off some local sites .
I have 7 now the low I gave was 25 bucks and the most is 40.00 they need paint but that is cheap .
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #8
Four of the 42 lb. suitcase weights will be all you will need to offset the bagger.
White Oak Boards (A65640)
White Oak Boards...
2013 LAY FLAT REEL TRAILER (A65643)
2013 LAY FLAT REEL...
2001 Freightliner FS65 School Bus, VIN # 4UZAAXAK01CH91008 (A65563)
2001 Freightliner...
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
Allmand 8KW Light Tower (A64194)
Allmand 8KW Light...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
