DO I NEED A BRACKET FOR FRONT WEIGHTS
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #1
KEYBEAR
Indiana
John Deere X-758
I need a little weight on the front of my X-758 . Thinking some suitcase weights would be the best fast on fast off . Do I need any kind of bracket or is the one already on the tractor used for the weights .
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #2
Yes, That front bracket is the weight bracket.
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #3
Fill front tires with either windshield wiper fluid, or better, the rim guard beet juice. See if that is enough weight.
Thanks I could not find any info in the manual or on line . I would fill the front tires but I only need the weight two or three times when I use the bagger . If I Vac grass it gets heavy and the front gets lite the rest of the time no need for weight .
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #5
The front bracket will hold 4 weights, if you need more there is a 9 weight bracket available from JD which also doubles as a heavy duty front bumper.
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #6
Picked up a weight (40#) at Dealer this morning.. $59
I have been buying weights all winter when I see them at a good price off some local sites .
I have 7 now the low I gave was 25 bucks and the most is 40.00 they need paint but that is cheap .
/ DO I NEED A BRACKET FOR FRONT WEIGHTS #8
Four of the 42 lb. suitcase weights will be all you will need to offset the bagger.
2844 (A58376)
2844 (A58376)
2025 Giyi CW59 Pad Foot Vibrator Roller (A62183)
2025 Giyi CW59 Pad...
2015 Polaris Ranger 570 (A62183)
2015 Polaris...
2004 Ford F-150 (A62180)
2004 Ford F-150...
Rhino 4155 15' PT Batwing Mower (A62180)
Rhino 4155 15' PT...
2012 Sunflower 5035-28 Cultivator (A63116)
2012 Sunflower...
