Do I have a rear hydraulic outlet block?
   / Do I have a rear hydraulic outlet block? #11
For an experiment...
Scan it as "text"
If any of the other choices have "2 Bit" ... try that.
If you have a black/white photo... then use "grayscale"...
Post so we can see /w3tcompact/icons/wink.gif
{more importantly... so you can see /w3tcompact/icons/blush.gif}
   / Do I have a rear hydraulic outlet block? #12
John, when I put a sheet of paper in the scanner, it offers the following choices: (1) text, 300 x 300 dpi, and "estimated size per page" of 1027k, (2) photo, 150 x 150 dpi, grayscale, size of 136k - that's what I used, but it actually came out to be 204k according to Windows Explorer, (3) grapic, 300 x 300 dpi, size of 547k, and (4) Other - custom settings (probably the best one to use if you knew what you were doing. I saved it as a .jpg file, put it in the directory with my other photos, then resized it downward to 920 x 1170 pixels and it was 160k (that's where I screwed up; I should have downsized it even more).
Bird
   / Do I have a rear hydraulic outlet block? #13
OK, now I've downsized it to 755 x 960 and I'll see how that looks.
Well, at least now I don't have to scroll across to see it all; it fits on my screen; don't know about others' screens. That's always a problem for me; I have no idea what size to make a copy or photo for it to look right until I post it and use up more of Muhammad's space. Then after it's posted, I don't know how to edit an attachment. I guess I could just delete the post and start over, though.
Bird<P ID="edit"><FONT SIZE=-1>Edited by Bird on 08/07/01 04:32 PM (server time).</FONT></P>
This clears it up, Bird! I will have to look tonight for that cover, and let ya'll know what I find.
john
   / Do I have a rear hydraulic outlet block? #15
I'd use "text mode" for b/w stuff. I said "2 bit", I meant "1 bit"...
On faxing stuff you'd use 200 x 100 for regular and 200 x 200 for fine.
On color 150 dpi {for decent reproduction} and always save as "jpg" for smallest file size.
   / Do I have a rear hydraulic outlet block? #16
Bird,
That looks great... save and remember those settings.../w3tcompact/icons/smile.gif
   / Do I have a rear hydraulic outlet block? #17
<font color=blue>remember those settings</font color=blue>
With my memory? Are you kidding?/w3tcompact/icons/wink.gif
Bird
   / Do I have a rear hydraulic outlet block? #18
Bird,
I couldn't help but note how helpful you have been on this thread. Your sure a handy fellow to have around. /w3tcompact/icons/smile.gif
Al
   / Do I have a rear hydraulic outlet block? #19
Thanks for the kind words, Al. I'm still just trying to learn myself and have fun; glad to help when I can. Too danged hot and dry around here to do much else; might as well play on the computer./w3tcompact/icons/wink.gif
Bird
   / Do I have a rear hydraulic outlet block? #20
Your loss of outside work is our gain./w3tcompact/icons/wink.gif
Al
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2004 FORD F-650 SUPER DUTY CAB AND CHASSIS (A58214)
2004 FORD F-650...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2007 MACK CV713 ROLL OFF TRUCK (A58017)
2007 MACK CV713...
2012 Chevrolet Silverado 2500HD 4x4 Service Truck (A56858)
2012 Chevrolet...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
