Do I have a rear hydraulic outlet block?
   / Do I have a rear hydraulic outlet block? #11
For an experiment...
Scan it as "text"
If any of the other choices have "2 Bit" ... try that.
If you have a black/white photo... then use "grayscale"...
Post so we can see /w3tcompact/icons/wink.gif
{more importantly... so you can see /w3tcompact/icons/blush.gif}
   / Do I have a rear hydraulic outlet block? #12
John, when I put a sheet of paper in the scanner, it offers the following choices: (1) text, 300 x 300 dpi, and "estimated size per page" of 1027k, (2) photo, 150 x 150 dpi, grayscale, size of 136k - that's what I used, but it actually came out to be 204k according to Windows Explorer, (3) grapic, 300 x 300 dpi, size of 547k, and (4) Other - custom settings (probably the best one to use if you knew what you were doing. I saved it as a .jpg file, put it in the directory with my other photos, then resized it downward to 920 x 1170 pixels and it was 160k (that's where I screwed up; I should have downsized it even more).
Bird
   / Do I have a rear hydraulic outlet block? #13
OK, now I've downsized it to 755 x 960 and I'll see how that looks.
Well, at least now I don't have to scroll across to see it all; it fits on my screen; don't know about others' screens. That's always a problem for me; I have no idea what size to make a copy or photo for it to look right until I post it and use up more of Muhammad's space. Then after it's posted, I don't know how to edit an attachment. I guess I could just delete the post and start over, though.
Bird<P ID="edit"><FONT SIZE=-1>Edited by Bird on 08/07/01 04:32 PM (server time).</FONT></P>
This clears it up, Bird! I will have to look tonight for that cover, and let ya'll know what I find.
john
   / Do I have a rear hydraulic outlet block? #15
I'd use "text mode" for b/w stuff. I said "2 bit", I meant "1 bit"...
On faxing stuff you'd use 200 x 100 for regular and 200 x 200 for fine.
On color 150 dpi {for decent reproduction} and always save as "jpg" for smallest file size.
   / Do I have a rear hydraulic outlet block? #16
Bird,
That looks great... save and remember those settings.../w3tcompact/icons/smile.gif
   / Do I have a rear hydraulic outlet block? #17
<font color=blue>remember those settings</font color=blue>
With my memory? Are you kidding?/w3tcompact/icons/wink.gif
Bird
   / Do I have a rear hydraulic outlet block? #18
Bird,
I couldn't help but note how helpful you have been on this thread. Your sure a handy fellow to have around. /w3tcompact/icons/smile.gif
Al
   / Do I have a rear hydraulic outlet block? #19
Thanks for the kind words, Al. I'm still just trying to learn myself and have fun; glad to help when I can. Too danged hot and dry around here to do much else; might as well play on the computer./w3tcompact/icons/wink.gif
Bird
   / Do I have a rear hydraulic outlet block? #20
Your loss of outside work is our gain./w3tcompact/icons/wink.gif
Al
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
1611 (A57192)
1611 (A57192)
2015 Komatsu WA380-8 Wheel Loader, S/N A74124, PIN# KMTWA130CFNA74124, Diesel Engine, Komatsu WA380 (A59076)
2015 Komatsu...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2021 Ford F-450 (A55973)
2021 Ford F-450...
