Do honey bees nest in ground?
   / Do honey bees nest in ground? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I can't say I've ever seen any kind of honey bee nest....ever.
Yesterday, I was on back side of farm collecting some rocks to border the wifes flower garden.
I backed my hoe up to the fence and was reaching out almost 20' to pull some rocks that were dumped there (decades and decades ago) closer to the fence.
There was a couple 10" diameter trees that had grown up through the pile of dumped rocks.
I pushed one over that was dead and ultimately, banged up the other one that it was sacraficed for the rocks.
During one of these events, I noticed a small swarming of insects. There was only maybe 30/50 of them BUT.... being sting allergic (although taking preventative shots for it) I scooted away for a while to let them calm down.
I went back to look, again, staying on the seat of my machine so I was maybe 20' away from them and still saw them. They looked TOTALLY like normal honey bees that you see on the flowers.
They did NOT look like yellow jackets nor hornets and they were not swarming nor attaking like I'd expect yellow jackets or hornets to do (ask me how I know)
If these were indeed, normal 'bees' then the implication was that they were nesting in the ground???
do they do that?
Maybe they had a nest in a hole in the tree I pushed over?
   / Do honey bees nest in ground? #2
If not yellow jackets then my guess would be a variety of bumble bee.
Was mowing broom sage field years ago went over an underground nest.
Got 14 stings neck & shoulder. They did not hurt nearly as bad as yellow jacket stings.
Do not think you found honey bees if coming out of ground, in the tree then good chance of honey.
Try to find a bee keeper and see if you can get a little honey, got some from eave of house a few years past. It was GOOD.
   / Do honey bees nest in ground? #3
I'm guessing honey bees possibly if they came out of the tree. If they came out of the ground, more likely they are a small yellow jacket that will swarm and sting. Better watch out until you figure out what you have.
This time of year, collecting rocks is also good activity for collecting snakes.
   / Do honey bees nest in ground? #4
When I was a kid, I had to help my dad get out first hive of bees by cutting down and splitting a hollow tree to take some of the honeycomb out and put it in the hive he bought, and for him to find the queen been in that tree and move her into the hive. Hollow trees, in between the walls of houses, etc. may have honey bees, but I never heard of them in the ground. Also when I was a kid, there were lots of bumble bees around. They seemed to especially like the blooms on my okra crop, so I've been stung by them while cutting okra. I always heard that they nested in the ground, but I've never seen one of their nests.
   / Do honey bees nest in ground? #5
Honey bees do not nest in the ground. Last year there was a ground nest of what looked like 1/2 size honey bees in my yard. Don't know what they were but definitely not normal honey bees or yellow jackets.
   / Do honey bees nest in ground? #6
If they did not swarm after you, they probably weren't honey bees or yellow jackets. They were likely bumble be nests with the quantity you described. They are not territorial and would likely take a lot to get stung by them.
I used them in the water melon field along with honey bees for pollenation. The bumble bee hives were expensive, but I felt much safer around them that the honey bees...They just didn't care if you were there or not, even if you tapped on their hive, it took a lot to get the riled up.
A true bumble bee is a lot smaller than people think. A lot of people confuse carpenter bees and other solitary bees with bumble bees, but a bumble bee is quite hairy and is not shiny at all.
   / Do honey bees nest in ground? #7
There are some species of Bee's that do nest in the ground.:)
   / Do honey bees nest in ground? #8
I have seen 1 honey bee hive in the ground. Well, mostly. The hive was below ground level in a mostly rotted out tree stump.
And I know what a honey bee looks like. Use to work 'em full time.
   / Do honey bees nest in ground? #9
Bumble Bees in Missouri must be alot different, if the nest is distrubed in warm weather you are in for an experience
I agree with the caution...this is why I lifted my stabilizers and moved away (rather far away). After going back, I only saw one/two buzzing about in the same location so I moved a rock again and then saw many more. I had zero intent of getting a close look so was content sitting in my seat nearly 20' away and letting them check out the bucket (which they were only mildly interested in.....no swarming towards it either)
As for snakes.... although I didn't think of snakes, I guess they weren't a big concern because again, I was doing all of this from the seat and letting the bucket do the work.
Futile for me to try to get down there with my hands, I have some pictures of some of the rocks posted in this thread
http://www.tractorbynet.com/forums/rural-living/175837-my-current-project-flower-garden.html
Interestingly.... we spent 4 hours adding more large rocks the other day (no where near as large as the first rock).... and yesterday, wife said she didn't like those so I had to move them and will be replacing them with others that are closer to the size of this first one.
   / Do honey bees nest in ground? #11
Interesting, Richard. I can't answer either, but every spring, I have some small bee-looking crits that make holes in the ground, coming in and out. I can't figure out what they are. They leave little tufts of dirt piled around their holes, and are very passive; I walk all over them with no problem. Probably not what you are seeing, but I would really like to know what you saw.
   / Do honey bees nest in ground? #13
From what I know, and the book I have, Bumble Bees establish colonies underground and are "peaceful and efficient gathers of nectar and pollen, much too busy to bother anyone unless their nests are disturbed." (Straight from the book....)
   / Do honey bees nest in ground? #14
Probably true. The only time I got stung by bumble bees was when harvesting okra and actually bumped or got hold of one accidentally. As long as I was careful to not touch them, they always left me alone.
   / Do honey bees nest in ground? #15
Even swatting at bumble bees is likely just to move them out of the way. Not to say they won't respond, but the are the most indifferent bee I have ever seen. There are strains,some a little more reactive than others, but non comes close to any wasp or honeybee that I know of.
Alright everyone now, can we say " Bumble Bees are our friends?" on three....1...2...:laughing:
   / Do honey bees nest in ground? #16
I am new to the board but thought I would respond to this question because I saw last summer what looked to be a honey bee hive in an old coyote den. I was on foot about 300 yards from my vehicle when I stumbled across them. This surprised me because I have never seen them nest this way before. I would have been in trouble if they were africanized and had gone after me. Didn't hang around long and just got out of the area as quickly as possible. Could have been a serious situation.
Roger
   / Do honey bees nest in ground? #17
3....:thumbsup::thumbsup::thumbsup:
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2018 FREIGHTLINER...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
