DK65 Rear Axle
/ DK65 Rear Axle #1
HTRDCowboy
Canton, TX
Kioti DK65
Okay I was going to working the tractor today. The last time I used the tractor I had it in four wheel drive. Today when I started to use the tractor I remembered it was in four wheel drive so I shifted it back to two wheel drive and the tractor wouldn't move. When I released the clutch I could hear a rattling, so unfortunately I didn't get to use the tractor. Does anyone have any idea what I need to start looking at to repair this?
TIA, Ronnie....
/ DK65 Rear Axle #2
Put it back in 4WD and in gear and jack up each rear wheel one at a time. If you can turn one, that's where the problem is. Likely to be a broken differential half shaft. If you can turn each rear with the opposite on the ground, things are worse.
/ DK65 Rear Axle #3
Double check that your High N Low gear lever is not slightly out gear that might have gotten bumped while taking it out of 4wd. it has happened to me before and I thought I broke something. Sometimes if it is just out of gear the teeth will still touch and make the rattling noise.
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2022 Chevrolet Trax SUV (A61574)
2022 Chevrolet...
Ford Tractor (A62613)
4021 (A59228)
4021 (A59228)
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
