DK65 Rear Axle
/ DK65 Rear Axle #1
HTRDCowboy
Canton, TX
Kioti DK65
Okay I was going to working the tractor today. The last time I used the tractor I had it in four wheel drive. Today when I started to use the tractor I remembered it was in four wheel drive so I shifted it back to two wheel drive and the tractor wouldn't move. When I released the clutch I could hear a rattling, so unfortunately I didn't get to use the tractor. Does anyone have any idea what I need to start looking at to repair this?
TIA, Ronnie....
/ DK65 Rear Axle #2
Put it back in 4WD and in gear and jack up each rear wheel one at a time. If you can turn one, that's where the problem is. Likely to be a broken differential half shaft. If you can turn each rear with the opposite on the ground, things are worse.
/ DK65 Rear Axle #3
Double check that your High N Low gear lever is not slightly out gear that might have gotten bumped while taking it out of 4wd. it has happened to me before and I thought I broke something. Sometimes if it is just out of gear the teeth will still touch and make the rattling noise.
2009 Stertil Koni ST-1082R 18000lbs 2-Post Auto Lift (A61573)
2009 Stertil Koni...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2020 Vikeen Rice Lake Rough Deck AX-1 Truck Scale (A61573)
2020 Vikeen Rice...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2015 Ford Transit 350 4x4 Sewer Viewer Van (A61573)
2015 Ford Transit...
(8) John Deere Tractor Weights (A64119)
(8) John Deere...
