Mowing DK53SE Rotary Cutter sizing
   / DK53SE Rotary Cutter sizing #1
Grant1
Middleburg Fl
Kioti CK30, Kioti DK45hst
I just purchased a Kioti DK53SE. Looking at the owners manual it lists a 65" maximum width rotary cutter for this machine. This seems small for a 53 HP tractor. I pulled an 8Ft Titan with my 2014 DK45hst with no problems. Did Kioti just reduce the capacity of the DK series or is this an error.
   / DK53SE Rotary Cutter sizing #2
I always went by the width of the rear tires .
   / DK53SE Rotary Cutter sizing #3
I agree with you. It does seem awfully small. I borrow my neighbor's 72" and use it with my 38 hp tractor with no problems.
Remember, these manuals are constrained by the lawyers/management who have to approve them. They have to protect the idiots that don't know how to use them, nor should use them, in the first place.
If you still have your 8' titan, I'd try it on some light material to see how the tractor performs, and then go from there.
   / DK53SE Rotary Cutter sizing #4
I agree. Your tractor will handle a bigger mower. Use the mower manufacturer hp requirements for deciding what will work.
   / DK53SE Rotary Cutter sizing #5
Kioti lists 63" as width of your tractor, so that's why they show 65" as implement limit size. But you know it can definitely pull a larger light duty rotary cutter.
   / DK53SE Rotary Cutter sizing #6
I HACE A 4110--41 HP-- AND PULL A 6 FOOT TOW BEHIND WITH NO PROBLEM.
   / DK53SE Rotary Cutter sizing #7
If you have an 8 foot titan, put it back there and give it a whirl. I think the worst that could happen is you'd have to go slower when hitting heavy stuff.
   / DK53SE Rotary Cutter sizing #8
I think everyone just has to make that call for themselves. What you are cutting makes just as much difference as how wide your cutter is or how much HP your tractor has. I have a 10' brush hog that I pull with A DK45...no doubt Kioti would have a conniption! I have very level smooth land on which I cut hay. When I am not going to make a hay cutting (early spring, late fall) I keep the grass mowed short, never cutting more than 2-3 inches. The tractor handles it very nicely in High range, 2nd gear.
I harbor no dreams that I could tackle waist high Johnson Grass!
   / DK53SE Rotary Cutter sizing #9
Ignorance gone to seed.
   / DK53SE Rotary Cutter sizing #10
I mowed 9 1/2' tall reed canary grass with my B7800 (53" wide) and a 5' RC. Slugs were able to get out of my way! Fortunately I was only doing that once (and now I mostly mow with my NX and a 6' RC, though I'm about to pull the trigger on a 7' flail).
   / DK53SE Rotary Cutter sizing #11
I pull a 7' farm king with my NX4510. I like that it's a bit wider than tractor. Can get closer to fences and buildings. If it gets really thick, I just adjust speed accordingly. You will have no issues with 8' Titan.
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2015 BMW 328i Sedan (A59231)
2015 BMW 328i...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2014 CATERPILLAR...
