DK50SE HST Cab
/ DK50SE HST Cab
. . . also, a heads up
If you have the detents installed on the second set of rear remotes, think about adding a loop to prevent deadheading the engine and hyd pump if you ever accidentally engage the lever without anything installed. Cheap insurance.
That's a great idea. My 2nd set of remotes does indeed have the detent. I intend to remove the detent asap, but I'll add a loop in the meantime just for safety. Thanks for the tip.
/ DK50SE HST Cab #42
i left the detent in cause i use a 3 point log splitter. cheap insurance...especially as Kioti warranty does not cover deadheading damage
/ DK50SE HST Cab
No log splitter for me. Or anything else that would use a detent . . . at least nothing I can think of. My main use for the 2nd set of remotes will be a hydraulic top link.
/ DK50SE HST Cab
I thought I would post a few pics of the stump grapple I got. Jury is still out on it.
One cedar down, hundreds to go:
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A66734)
2025 Kivel 42in...
2012 Mercury 25HP Outboard Boat Motor. (A66738)
2012 Mercury 25HP...
2009 PETERBILT 388 FLATTOP SLEEPER (A67714)
2009 PETERBILT 388...
WHOLE PART ROOM (A68842)
WHOLE PART ROOM...
