DK45SE wont start
/ DK45SE wont start #1
otherguy
MO
Kioti DK45SE
I started another thread about the battery but now that I tried a fully charged Marine Deep Cycle battery and it still wont start are there any easy things that I can check out? Just remember I am not the most mechanically oriented person nor am I that familiar with the tractor yet.
Basically I turn the key until the glow plug light goes out, then when I turn to start all I hear is one click from something and that is it. Nothing else happens or even attempts to happen. This did happen the last time I used it (few of weeks ago) and it did this same thing, but I went inside for something and when I came back out I thought I would try it just to see and sure enough it started, but not this time.
Thanks
/ DK45SE wont start #2
Make sure you are in neural and pto is off. Then sometimes you need to move the shifter a bit to line up. #1 start at batt is there 12.5 volts or better?
/ DK45SE wont start
I did notice that the lever was in Forward and not Neutral yesterday, I think my son was messing around on it, but that didn't help moving it back. I checked all other levers and switches that I could think of and they all looked to be in the position they should be.
/ DK45SE wont start #4
Did you try the headlights - are they bright ? Could be a ground ? I'm not sure a Marine Deep cycle battery is ment to be a starting battery .
/ DK45SE wont start #5
Starter relay ?? I've had deep cycle marine battery's in all my equipment for years with no problems.
Starter solenoid ? Try and determine what is clicking.
/ DK45SE wont start
I finally got it started after reading some old post about ignition switch issues that Kioti use to have or maybe still does. After the glow plug light went out I turned the key from that position to start a few times quickly. After about the third time it finally triggered and it started right up.
At least it looks like I can get it started but who knows how long this little trick will last. Now knowing that it is not the battery and could be the switch is that what I should change first?
Is the switch easy to change?
/ DK45SE wont start #7
The dealer gave me a new switch mons. ago but I've not got around to installing it so no help but I'm sure you'll figure it out the new one just plugs in.
/ DK45SE wont start #8
Squirt some electrical contact cleaner or wd40 in the key hole and cycle the key a few times.
/ DK45SE wont start #9
I did what ritchey said last fall and it's still working so the new one is still on the shelf.
/ DK45SE wont start #10
I have rebuilt the ignition switch several times. There are indents and a ball bearing. Be careful taking it apart. The Bearing is spring loaded and can fly anywhere... take pictures as you take it apart.
/ DK45SE wont start #11
As bad as the switches can be the starter relay up on the firewall fails more often. I lubed up the switch years ago and it has been perfect since. They are pretty easy to change out, there is a molex plug on the end of it, but several have taken them apart and cleaned them up. I squirted fluid film in mine some time back. if you want to see what it looks like, here is my thread about lubing up the throttle linkage, but you can see the switch and molex in the photos.
http://www.tractorbynet.com/forums/...ottle-lubrication-pix.html?highlight=throttle
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
Trimble True Count Clutch Wiring (A65640)
Trimble True Count...
2023 Dodge Ram Crew Cab - Built to Serve Edition (A66408)
2023 Dodge Ram...
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
