DK45SE HST
/ DK45SE HST #1
tooln
North Central WI
Kioti DK45SE-HST
Monday I'm going to look at a DK45SE HST. The price quote I have is $22500 with a loader. Does this sound like a fair price? Also it has R4 tires on it. I was thinking that R1 maybe a better options for me as I plan on skidding log this winter. But the R4's are rated for heavier loads and I'll also be doing a lot of loader work. I could always put chains on the R4's. I know the R1 vs R4 debate is endless. How about your opinions from those who have had both. Thanks hopefully to a new tractor owner come Monday.
/ DK45SE HST #2
Yes, that is a good price. Yes R1's have more traction in muddy conditions. Yes R4's are better for loader work. Yep, chains on R4's make a huge difference. You are lucky to still find a DK45se HST in stock.
/ DK45SE HST #3
That's almost $3000 less than I paid for mine 2 1/2 years ago, and I thought I got a real bargain as mine was $10K less than the nearest competitor on my shortlist with the implements I bundled in. Is it new or used?
/ DK45SE HST #4
Price sounds fair, as far as tires, I am happy with the R4s on mine, make sure to get the rears loaded.
Before buying my tractor I used my Dads JD with R1s on my property and it left bumpety bumps every where when the the ground was damp at all.
The 10-16.5 R4 fronts also squat less that the skinny front R1s under a heavy loads.
They are a good tractor, don't snooze on the deal, as Koua said, you are lucky to have found one.
/ DK45SE HST
I have not seen it yet but I'm told it's new.
/ DK45SE HST #6
You be very lucky to get this deal as my Dealer has been out of DK's for awhile now.
/ DK45SE HST #7
I would be down there today with a "sold" sign to put on that one.
/ DK45SE HST #8
Ditto on all the go get her now posts!
If it's the Tier 3 emissions, vs. the newest Tier 4 package, grab it before someone else does. You won't be sorry, they're great tractors!:thumbsup:
Post back results.
/ DK45SE HST #9
Very fair price IMHO.I have had both R4, & R1s.My choice are the R1,s as I live where we get a lot of snow and muddy conditions in the spring and fall.
/ DK45SE HST #10
Sounds like a great deal considering the scarceness of the DK's. We all have our own opinions on the R1's vs. R4's. My previous tractor had R1's, my Kioti has R4's. Overall, I'm glad I went with the R4's but in the greasy clay you sometimes find around here and in snow (I have to use rear chains), I had better traction with my old R1's.
/ DK45SE HST #11
Yes that's a good price for a new DK. Snatch it up while you can!
/ DK45SE HST #12
I got mine last year for 25k, so it sounds like a big time deal. I love my R4s, much easier on the turf.
/ DK45SE HST #15
tooln, I got the same price in June but asked them throw in an extra set of rear remotes for that price. See if they will do that for you or service manual or first service filters or all the above. It never hurts to ask. Overall its a good price if they do not move on the adds. I think you will pleased with the DK45, it has done all that I ask and more. Good Luck and welcome.
/ DK45SE HST
Who did you buy from & where is Meatloaf Mtn WI? I live in Marathon Co with property in Clark.
/ DK45SE HST #19
That looks like a deal, the DK is a great tractor, out of production now, Tier III, and very hard to find now. I was quoted that plus an upcharge for financing. On R1 vs R4, I'll take R1. Compromises make no one happy, and R4s are a compromise between turf and ag tires. If you're doing lawn care work, go with turf, if beating up the ground is not a concern, get ags for the best traction. If you're working in snow, the industrials will just fill up with snow, slush, and muck and spin. I know industrials are good on hard ground, but that's it. Both tires will support as much as the loader and front axle can bear. Basically, get R1s if you want traction. (in case you can't tell, I have ags on my CK)
/ DK45SE HST #20
I do a lot of work in the woods and a lot of heavy loader work the R4's have heavier sidewalls both are better for stumps and sidewall flex. I am close to 500 hours and have not been stuck yet. So I have been happy with the R4's and would buy them again. CJ
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 FREIGHTLINER...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2020 Ford Fusion Hybrid Sedan (A66738)
2020 Ford Fusion...
PALLET OF CUT-OFF VALVES (A68842)
PALLET OF CUT-OFF...
