DK45SC Cab Liner Mice!
   / DK45SC Cab Liner Mice! #1
billboe
Vermont
Kioti DK45SC w/ Backhoe
Before I just start removing bolts willynilly, what is the best way to get into the cab liner on a DK45SC? I've got some serious stink up there!
There is a youtube video of a guy removing the top of a NX cab. Is it the same on DK?
THANKS ALL!
Billboe
p.s. While I'm in there I'm thinking of replacing the exterior lights. I guess I should post a separate question for that...
   / DK45SC Cab Liner Mice! #2
the dk cab has bolts up on top. the bolts have a rubber insert on them. i think there are 4 as far as i recall. be aware the front cab lights may interfere with lifting it up. it just hinges up.
   / DK45SC Cab Liner Mice! #3
This is for my 2010 DK45
   / DK45SC Cab Liner Mice! #4
I replaced mine years ago with led. The led are super bright
heres the thread
   / DK45SC Cab Liner Mice! #5
Mouse smell is just nasty....good luck!
grsthegreat! you're awesome! i believe mine is a 2006 so i'll check it out and report back.
THANKS!
   / DK45SC Cab Liner Mice! #7
Hope it works for you
turns out my model doesn't have a hinged top. there are 4 bolts (one at each cab light) that you need to remove and the cap lifts off (a wee bit awkward by myself).
there was a nest just under the cap (mostly just leaves, etc.) but the bigger mess was inside the heater/air conditioner unit. many screws and more clips later, i got it taken apart and began the cleanout. there was still a live "squatter" in there (kinda cute i must admit). i presume it left because i couldn't find it after retrieving the shopvac...
there appears to be many options for the mice to enter the headliner. via the cab seems obvious but perhaps up the vertical supports as well. as far as getting in the hvac system, they only way i've seen thus far is via the ducts inside the cab?!!?
anyway, i have more cleaning to do and then i'll figure out how to keep them out (or at least deter them). fun fun fun!
p.s. i had that smell in my nostrils all last night! it seems to permeate everything!
   / DK45SC Cab Liner Mice! #9
Mouse smell will continue to draw mice for years so you have to clean the area. Clean everything with a cleaner like Lysol first and throw some Fresh Cab packets up there to deter future mice. I find the Fresh Cab smell to be pleasant too.
Fresh Cab® Botanical Rodent Repellent Pouches | EarthKind
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
Red Military Truck (A53422)
Red Military Truck...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
Metal Bull Smoker (A55853)
Metal Bull Smoker...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
