Comparison DK45 vs DK50 vs NX4510
   / DK45 vs DK50 vs NX4510 #21
As long as it doesn't use exhaust fluid, I don't think it matters to me either way. I remember when it was a joke to ask people if they'd checked their muffler fluid...
It matters trust me. You have to run them a certain way, they have to be loaded to a certain %, you cant let them idle only so long. And you get the added bonus of paying more for more problems. To your original question, buy the most HP you can afford. I wish mine was a DK60, that would be just about perfect. I will occasionally lug mine down chained up pushing/stacking snow in medium range and digging in dirt in low range. I am picking up [finally] a 7' twin auger blower today so we will see how the 38 HP PTO works with that. More HP is a good thing. CJ
Lug down to the point where it stalls out? I expect a full report on that snow blower!!
   / DK45 vs DK50 vs NX4510 #23
I've got the DK50SE HST Cab and I like it a lot. Mine also has the stiff throttle, and I've been intending to lube mine up too.
If you buy one, be sure and get an extra set of rear remotes. I've got two sets and I wish I had three because I use one set for my grapple, and the second set for the hydraulic rippers on my box blade. I'd like a third set for a hydraulic top link.
   / DK45 vs DK50 vs NX4510 #24
how much would you give me for the equipment to make a third one. You do the install.. PM me if your interested.
   / DK45 vs DK50 vs NX4510 #25
Seeing as there is no 3rd OEM rear remote valve, are you talking about getting another 2nd remote and modifying to be a 3 valve set??? :confused3: That would be VERY :cool: It is easy to do with a diverter valve, but to actually have an OEM type 3rd set would be soooooooooooooooo nice. :thumbsup:
   / DK45 vs DK50 vs NX4510 #26
Well Actually I was going to use a Fasse stackable Diverter valve. So he could add more if he wanted later.
   / DK45 vs DK50 vs NX4510 #29
Yep, pretty slick.. 4 remotes in a jiffy, All neatly controlled by a single rotary switch, and your existing SCV.
Actually there are 3 separate switches in the control grip on the OEM control lever. ;)
   / DK45 vs DK50 vs NX4510 #30
You could do that, but why would you need them on the joystick or the SCV lever. , I would think dash mounted would suffice and save the money of the fancy control knob.
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2016 (INOPERABLE) FREIGHTLINER SD122 (A52472)
2016 (INOPERABLE)...
