DK45 PTO problem
/ DK45 PTO problem #1
wyguy01
gillette, wyoming
case 1070, kubota 7040, mahindra 6520
PTO will not kick out unless releay in fuse box is pulled any ideas ?
/ DK45 PTO problem #2
Well it is electric over hydraulic.. so I would pull the plug on the PTO solenoid and see if the problem is in the switch or is the solenoid sticking, or what..
Do you have the workshop manual.. If not and you intend to fix it yourself, you will sure need it. It is kinda complicated especially with the auto pto microswitch in the fender actuated by the position control lift handle. by the way make sure the auto pto switch is turned off.. I assume you did that already.
/ DK45 PTO problem #3
Looking at a DK45-50 schematic, if the PTO push button and the auto switch (with 3-point raised) won't stop the PTO , I think the actual relay must be the problem.
Toro Reelmaster 4000 D Mower (A65579)
Toro Reelmaster...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
7002SFL (A61572)
7002SFL (A61572)
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
2013 Chevrolet Express Cargo Van (A64556)
2013 Chevrolet...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
