Price Check Dk4210se hydrostat cab w/ loader
/ Dk4210se hydrostat cab w/ loader #21
Good to hear, I may have to order one soon!
/ Dk4210se hydrostat cab w/ loader #22
Thanks for the information guys the DK Cab tractor seems pretty hard to beat!
/ Dk4210se hydrostat cab w/ loader #23
IMO Kioti are the best and hard to beat. Can't go wrong buying a Kioti. :thumbsup:
/ Dk4210se hydrostat cab w/ loader #24
I own a Kubota 3301L and it is a good tractor with almost 400 hours. I have been looking at trading up to cab tractor with air and heat. I have looked at Kioti DK4210SE and Kubota L3560HSTC. Both are nice tractors. I am curious after owning your Kioti DK4210SE or Kubota to give it a good test how you are liking it and any pros or cons. And would welcome any opinions on either these Kioti or Kubota tractors from actual owners. I am not set in stone on just the Dk4210 SE but it was what the dealer recommended for my uses and that I would like to go a bit bigger size. I owned a Kioti ck 2501 for years and it was a great tractor and loader.
/ Dk4210se hydrostat cab w/ loader #25
I purchased my Kioti DK4210SE Cab model about 18 months ago.... and it has been absolutely flawless. Only recently have I ever used the heater but I have used the AC a lot! I can't say enough about this brand/model. My previous (first) tractor was a Kubota 2501. Another wonderful tractor that I only had for about a year - but which taught me what i wanted/needed in a tractor. Like many owners, perhaps my largest concern was about the emissions and if these would present a reliability problem. I do lower the rpm to idle when I hop in and out of the cab to pick something up or to change the bucket to the forklift, etc, but when I am operating the tractor I do keep the rpm at the lower eco-pto mark on the tach. I think this is roughly 1700 rpm. Admittedly, there are likely many tasks I could complete at a lower rpm but I think this RPM helps the engine to be a little cleaner. With about 150 hours on the clock, I have witnessed ~3 DPF cycles. A light comes on in the dash and my strategy has been just to keep working. In each case, the cycle completes itself in about 5-7 minutes with absolutely no inconvenience to me. Once completed the light goes out.... and I won't see it again for another 20-40 hours? I am conscious of these DPF cycles and I have tried not to turn off the tractor during one of these infrequent events... although you are supposed to be able to.
Anyway, I would highly recommend this tractor. I think you would really love it - as I do!
/ Dk4210se hydrostat cab w/ loader #26
I have a switch on my NS 5310 for that dpf..does yours? I haven't had one happen yet(only 30hours) but what your saying is when it does happen I don't have to hit the switch it just does it automatically? That dpf but always confused me...I do run the tractor at 2500-2600 rpm all the time other than warm up and cool down..
/ Dk4210se hydrostat cab w/ loader #27
Yeah, you don't have to hit the switch at all. I think the switch is in case you wanted to manually go into a DPF cycle. If you're fine at that RPM, then that's good. I think it is a little on the high side. I'm running normally around 1700 RPM and no that I've seen a few DPF cycles without drama, I find myself spend more time between 1000 (idle) and 1700 RPM. No problems or issues so far! I use it for all kinds of silly tasks - mostly because I am lazy. I've gotten pretty good at swapping between the bucket and the pallet forks! I use the pallet forks and an empty pallet to move stuff around quite frequently.
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
Volvo VNM (A63688)
Volvo VNM (A63688)
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
