Price Check Dk4210se hydrostat cab w/ loader
/ Dk4210se hydrostat cab w/ loader #1
Sbalak
Member
Lunenburg, MA
2018 Kioti DK4710SE Cab
I was quoted a cash price of $27,250. Anybody else get a quote on this model lately?
/ Dk4210se hydrostat cab w/ loader #2
That sounds pretty good. I believe i was at $36k for a 3510se cab with loader and backhoe cash price. The smaller framed tractor is typically more expensive due to demand i believe. I think my backhoe was $7800 so thatd put me at 28,200 for cab and loader, but he gave me great trade price on my old rig. Sounds like good bang for buck on that DK
/ Dk4210se hydrostat cab w/ loader #3
Just got quote on DK4210 SE Cab with loader, last week. $28,400 cash or $31,900 financed. Additional $150 off for military/first responders.
I pulled the trigger and brought home a new DK4710SE cab this weekend. 20181210_080053.jpg
/ Dk4210se hydrostat cab w/ loader #5
That’s a really beautiful picture. Love the new DK4710SE, sheep, alpaca’s, and architecture.
Congrats!
/ Dk4210se hydrostat cab w/ loader #6
The critters seem to LOVE it! Or maybe it’s the hay :)
So far so good. Previous tractor was a Kubota B3030 and the extra power and weight works well. Kubota was a good machine, but I was really at its limits all the time. Yeah, the pacas and sheep love the hay, but I think they're learning the noise difference of the two tractors. When I fire up the Kioti they come running to the fence to see what I'm bringing in. :) Has anybody here put a third function on DX SE Cab?
/ Dk4210se hydrostat cab w/ loader #8
I pulled the trigger and brought home a new DK4710SE cab this weekend.View attachment 582583
That is a nice machine does it have AC in it or just heat? What is that red bar that seems to be running along the bottom of the machine?
/ Dk4210se hydrostat cab w/ loader #9
That thing looks BAaaaaaaahaaaahhhaaaaaaaad!
It has both AC and Heat. They both work really well regardless of the outside temp. There are two undercarriage protection bars the run under the DK. They look a little red in the picture, but they're the same orange as the tractor. You really notice them on the right side of the tractor because there's no step or fuel tank there.
So far so good with the Kioti. It has ~8 hrs on it. It clicking off hours faster with it than than the Kubota. I believe it's hour meter is on/off and the Kubota was mechanical + tied to engine RPM. Since I spend most time in lower idle I think my actual hours on the Kubota were probably double.
/ Dk4210se hydrostat cab w/ loader #11
Congratulations on the new machine.
The older DK's were mechanical meters
My 2001 DK 35 is mechanical (with tach cable).
At or near PTO speed register for 1 hour =1 hour on the meter. Lower RPM's the hour meter registers hours slower.
/ Dk4210se hydrostat cab w/ loader #12
I have wondered about these bars on my DK5010HS. Are these bars considered a subframe should I add a backhoe to my DK some time in the future or would I need a backhoe with a subframe included?
Peter
/ Dk4210se hydrostat cab w/ loader #13
Hi, I'm in Nova Scotia, I bought a new DK4210SE HST with a backhoe (KB4285) the hoe comes with a subframe. The long orange rails under your tractor are for support for the Loader, and to give the machine support and distrubute stresses across the machine. The backhoe subframe is too small for the DK it rubs the seat against your cab unless you move the seat up a few notches, but then it's kind of crowded. I've already ahd this fight with Kioti and I got no where.[
ATTACH=CONFIG]587472[/ATTACH]
/ Dk4210se hydrostat cab w/ loader #14
Thanks for that clarification. I am open station so the backhoe seat may not rub. Keep me in mind if you ever decide to sell the backhoe or even want to get some rental income off it. . Nice looking set up you have there. Good luck with Sunday's storm!
/ Dk4210se hydrostat cab w/ loader #15
Thanks. This is the biggest backhoe Kioti makes it goes on all their larger models if you wanted to buy one I think they're around $11,000 new. I may never get my money's worth out of it but it's the second tractor I've owned and I've had backhoes on both of them and I really like the option. I'm always open to helping folks out PM me if you have something in mind for a rental someday cheers!
/ Dk4210se hydrostat cab w/ loader #16
Hello Sbalak How do you like the Kioti so far? I just looked at them as well I did have an L3560 cab tractor before, I am in the market now. At a glance they look great! I am on the fence looking at the DK, NX and the Yanmar 359. Love to hear your thoughts. Does it have enough power, how is the lift capacity and any issues at all with yours?
I still like it. :) I think there are some things that I'm still getting used to, but I don't know if that's Kioti vs. Kubota or just smaller tractor vs. bigger tractor.
1. The Kubota weighed 60% less, but had only 30% less HP. I could have the kubota in any gear (hydro) and go forward or backward at low idle. The Kioti definitely wants more than idle RPM for high gear and loader operation. It's possible to stall the tractor, which not something that would happen on the B3030 unless it was the PTO driven (ie post hole digger stuck).
2. The hydro gear range is a little different. I think the range is a little larger for all gears in the Kioti. I found that low in the kutoba was a creeper gear I mostly used for aggressive loader work. I rarely used it, so I tended to not use it in the Kioti but I'm learning that's not really valid. Low is Kioti has enough range to keep in low and still move fast "enough" for small moves. I find that I use all gears on the Kioti more, because I can shift without looking down. It's very natural to lower your arm and shift.
3. The Kubota's throttle was mechanically linked, but the Kioti is software controlled. I've noticed that I can raise the throttle on the Kioti and the engine doesn't necessarily increase RPM if it think it doesn't need it. Sounds good, but I've found that I can fool the engine. I've been in M going down hill and increase the throttle without the engine increasing RPM all the way to the point where the throttle is maxed but RPM doesn't change. I can then stop, reduce the throttle back to idle and then raise RPM with increased throttle. I think it's kind of throttle bug. This tractor has E-540 PTO so throttle, PTO speed, axle speed, and engine RPM are not all 1:1 at times. Again....maybe this is user error, but so far I just never really do any work with the tractor at low idle, while I did a lot of work on the B3030 at low idle.
4. The Kubota 4WD was pretty much engaged all the time. I find that with the Kioti I only engage the 4WD when I'm on dirt. It has too much traction to use 4WD on asphalt, which results in jumping during a turn. I find that the Kioti is a little harder to engage into 4WD sometimes. I think the transmission is a little beefier and doesn't want to disengage sometimes. In those cases I just slow and sometimes reverse and then it shifts to 2WD. This might be because the tractor is still very new.
5. The hydro on the Kioti whines more than the Kubota. I don't know if that's a new tractor thing or if its always there. Its not enough to be annoying, but enough to be noticeable.
6. I'm still getting used to the hydro peddles being side by side rather than the treble peddle. This is mostly a muscle memory issue for me. The problem with the treble peddle is mud and muck. I never thought it was hard to use, but without fail I get mud/snow under the reverse and have to clear it.
Things I really like:
1. The loader is much stronger than my smaller tractor. I have a titan QA pallet\hay fork for it. The kioti easily lifted 1200lbs of quikcrete out of the pick-up with ease and no ballast. I picked up some large tree sections and have decided I need to make a ballast box for the back. I was able to lift up the rear, but I don't know how much those sections weighed. I'm guessing >1800lbs.
2. The extra weight and tractor is night and day compared to the lighter Kubota when traveling in mud and doing loader work. I liked my B3030, but I needed a bigger machine. I've taken the Kioti through mud and muck that have repeatedly got the B3030 stuck.
3. The cab is nice and the HVAC works very, very well. Even when its really cold, the engine still gets to middle temp quickly. You can easily make it too hot/too cold regardless of the outside temp.
4. I really like the extra 3pt lift level. This works so well and makes putting on attachments easy. The kubota had fancy adjustable link arms and the Kioti does not, but I'm still faster putting on attachments because I don't have to keep raising and lower the arms from the side of the tractor.
5. I didn't have QA on the Kubota front loader and I really like that on the Kioti. I had bolt on forks and I hated them. So much easier to have dedicated forks that come on and off in less than a minute. I still haven't welded on some hooks onto the bucket, but I miss that I had that on the Kubota bucket.
6. The steering is effortless and it has a great turn radius.
Problems I've run into:
1. I had the load valve freeze up on me. I think others have complained on this as well. The loader control was stuck so I could lower and curl, but couldn't raise. I think moisture froze inside some of the level linkages. I took apart the cover, but after a quick TBN search figured out the problem. I turned the heater on high and it fixed itself in 20 minutes. It was a very cold night, but for comparison the Kubota never had this problem and it lived the majority of its life in MN where the temps were much, much colder.
2. I had the 3pt lock up on me when taking of the post hold digger. I lowered it onto a pallet with the tractor off. I kind of got it stuck so I fired up the tractor to raise it, but 3pt was not responsive. I read elsewhere on TBN that if that happens just hit the rear hydros and it will clear the 3 point. Sure enough. Worked immediately. Again....never ran into this with the Kubota.
Things that could be improved:
1. I had LED lights and the Kubota (after market) and the Kioti does not. I plan on switching the lights over to LED. They're just not bright enough.
2. The tilt steering on the Kubota was nicer than the Kioti. My Kubota had a foot peddle to unlock the tilt so it was very easy to adjust to tilt every time you get into and out of the tractor. Kioti uses a lever which requires your left arm, but that's always on the transmission because the DK has to be started in N. I new this going in so not too big of deal.
/ Dk4210se hydrostat cab w/ loader #18
Thank you so much to the details on this machine. So the million dollar question would you buy another Kioti or would you get something else and if so what would that be?
I've only got 15 hours in, but so far I'm happy with my choice. If I could do it all over again, I'd stick with my same Kioti. Maybe I'd get the no-stall or linked peddle option, but I just can't see spending the extra ~$8k on the equivalent Kubota. IMHO...there's not that much difference in the machines.
/ Dk4210se hydrostat cab w/ loader #20
Linked peddle is an option the dealer can put on, I had cruise, Linked peddle, Extendable rear links, arm rests put on my DK 4210SE HC by the dealer for about $800 CDN.
