DK40SE Air Filter
/ DK40SE Air Filter #1
freewookie
Guthrie, OK
JD GT235, DK40SE HST
How do you blow it off? Manual says blow from the inside out but I could have sworn my dealer said to never clean it that way.
/ DK40SE Air Filter #2
Don't, replace it. It was discussed in Compact Equipment Magazine a few years ago, and for much bigger an expensive equipment; by experts in the field of equipment maintenance. Bottom line: replace, DON'T try to clean air filters.
/ DK40SE Air Filter #4
If you are going to blow out your filter, blow it from the inside-out.
Blowing from the outside pushes dirt farther into the filter.
That said I never blow out my filters. Too much risk of blowing a small hole in the filter IMO.
If its dirty replace it with a new one.
/ DK40SE Air Filter #5
I would be replacing my Filter 4 to 5 times a year if I replaced it when dirty. I bump it against a tire then use very low air pressure and clean from the inside. Bush hogging clogs them up pretty quick.
/ DK40SE Air Filter #6
I use a vacuum cleaner on the outside. Then hold it up to the sun and look thru it for any holes. Discard it if you see any. The vacuum cleaner does a good job and is gentle.
James K0UA
/ DK40SE Air Filter #8
Thanks for the link.
The DK filter gets dirty pretty quick doing loader work if your material is dusty.
Most heavy construction rigs, loaders, dozers etc have a inner and outer filter, so that if the outer filter is compromised you have a backup.
I was surprised that the DK was a single filter.
I crossed that carquest number to Napa (wix filter) 6489 Part Detail
It says to use with 6490 inner Part Detail.
This is the route I will be going, providing it all fits the airbox correctly.
This should take the risk out of cleanings in between filter replacement:thumbsup:
I spent a few years servicing heavy equipment, the inner filter lasts a long time if your outer is never compromised, cheap insurance IMO.
/ DK40SE Air Filter #9
If you wanted a cleanable filter and like K&N products, here's the cheapest place I found to get one. It's the same size as the original paper filter and crossed from K&Ns site. K&N E-4962 Replacement Industrial Air Filter | AJUSA.COM
My experience with KN air filters....back in 2000 I built a Jeep TJ for offroad use.
I put a drop in KN filter in the factory Air box.
First trip out with the KN it was pretty dusty, I was skeptical about the KN because you can hold it up to the light and see holes in it.
I pulled the air tube off when I got home,and the inside was covered with a very fine coating of dust.
The new KN went into the garbage.
/ DK40SE Air Filter
Now that I think about I'm thinking mine has an inner too. That may have been what he was saying not to blow out. I'd go out and look but the rain is starting...
/ DK40SE Air Filter #11
You don't have a inner filter.
The Napa filter lists a inner to go with the outer, I should be good through the winter, I just cleaned mine again, snow will be here soon, so no dust.
I have 60 hours on my tractor, I've cleaned the air filter 4 times, it was pretty dirty each time.
I will replace it next time, when I do, I am going to try the napa filters that I listed above, and see if they fit the airbox correctly, that way I can have a inner and outer filter.
If anyone tries this before I do, please post up.
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
NEW HOLLAND 355 FEED MILL (A64277)
NEW HOLLAND 355...
2013 Nissan Pathfinder SUV (A64557)
2013 Nissan...
