dk40 front end
/ dk40 front end
it appears the ring gear did'nt have shims installed which may have allowed the backlash to move out and shear teeth. they will be shimming the new ring gear and hopefully take care of that problem.
/ dk40 front end #12
Jack,
Once you get the tractor back you can work the heck out of it but when the wheels dig and bounce up and down you will break it the next time. I have built a few kioti front diffs and it is not a pretty site when the blow apart. Work it hard but try not to bounce it because these front axles don't like it.
The front drive shaft does not have a shear pin, just two splice couplers on each end. As you noticed the diff will go before anything else. Good luck
/ dk40 front end #13
<font color="blue">Work it hard but try not to bounce it because these front axles don't like it. </font>
I don't know of any axle that likes that. /forums/images/graemlins/grin.gif
RedDog
/ dk40 front end
I was'nt bounceing the front end when it happened. but I will work it a little differently next time. although I hate to baby it because I'll never get any work done. mabe I'll just have to chip away at things in smaller quantities from now on.
/ dk40 front end #15
</font><font color="blue" class="small">( I was'nt bounceing the front end when it happened. but I will work it a little differently next time. although I hate to baby it because I'll never get any work done. mabe I'll just have to chip away at things in smaller quantities from now on. )</font>
Could be that just because it wasn't repaired correctly in the beginning, as you indicate, it had nothing to do with bouncing and you can continue to use it as you have.
John
2001 FORD F-150 (INOPERABLE) (A60736)
2001 FORD F-150...
2011 DOOSAN G40 GENERATOR (A60736)
2011 DOOSAN G40...
2014 18ft. Top Hat T/A Trash Trailer (A60352)
2014 18ft. Top Hat...
2020 Bobcat T76 R Series (A60462)
2020 Bobcat T76 R...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
LaneShark L53 (A60463)
