DK40-- add a 3rd remote?
/ DK40-- add a 3rd remote? #1
IXLR8
Elite Member
Eastern Shore- Virginia
Kioti DK-40SE
I have 2 rear remotes on my DK40, both are being used for T-N-T, I am considering adding hydraulic angle to my rear blade. What is the easiest way to get a 3rd remote to the tractor to be able to angle the blade on the move? I haven't seen where Kioti offers this option.
Thank you
/ DK40-- add a 3rd remote? #2
As far as I know the "easiest" way is a diverter plugged into one of the existing remotes that makes 2 remote connections. So you wind up with 3 connections.. For example hook up to the original you are using for "tilt" and hook the "tilt" connection back up to the solenoid energized port of the diverter and hook up the blade angle to the non energized port, and use your existing factory remote lever to operate both, depending on the position of the electrical switch to operate the solenoid of the diverter. This should be a simple install, just mount the diverter, runs some electrical wire, and some hoses and connections.
I believe Brian, one of our members sells a kit for this (see link below) if you are interested, or you could source it out yourself from Surplus center.
valves
/ DK40-- add a 3rd remote? #3
valves
Thanks James. :thumbsup: I happen to agree, once the OEM remote options have been reached, adding a diverter or even diverters is the way to go. Believe it or not, it is actually common to need 2 or even 3 additional remote sets and this can easily be done with the diverters. ;)
/ DK40-- add a 3rd remote? #4
That's my next project to add two diverters to my third rear remote for blade angle, and offset.
James & Brian- Thank you for the information. Now that I know how to add another remote I can start to research the best way to add hydraulic angle to my blade.
/ DK40-- add a 3rd remote? #6
Jim, if you can get a couple of pictures of your blade, I would be happy to make some recommendations. ;)
/ DK40-- add a 3rd remote? #7
If you're not using your FEL, just run two longer hoses to the FEL connections.
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
Big John Semi Trailer (A65640)
Big John Semi...
2009 Ford F-150 Pickup Truck (A64194)
2009 Ford F-150...
2022 YANMAR VIO80-1A EXCAVATOR (A63276)
2022 YANMAR...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
