DK 55 Shuttle
/ DK 55 Shuttle #31
Well I just went outside and gave it a try on my DK35,it works-no grinding.I just rolled forward pushed the clutch in and pulled the shuttle shift back without hesitation and went into reverse on the move.Thanks for the tip. /forums/images/graemlins/grin.gif
/ DK 55 Shuttle
That should speed things up while your playing....er working /forums/images/graemlins/grin.gif
/ DK 55 Shuttle #33
realy and truly, a shuttle, if operated by an OPERATOR, is almost as fast as a hydro, and a lot less expensive.
/ DK 55 Shuttle #34
</font><font color="blue" class="small">( it works... what can I say? JUST MY OPINION... I still dont like the idea of throwing anything into forward while still traviling in reverse, or vise-versa. )</font>
Virgil,
I agree!! /forums/images/graemlins/smile.gif
RedDog
/ DK 55 Shuttle #35
</font><font color="blue" class="small">( realy and truly, a shuttle, if operated by an OPERATOR, is almost as fast as a hydro, and a lot less expensive. )</font>
Very true!!
JSDK55, I want to congratulate you on pointing out how stupid the rest of us (Kioti) owners are. /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
RedDog
/ DK 55 Shuttle
No problem. But I was starting to wonder if I wasn't the dumb one here. I never thought that bringing up a problem would lead to such a discussion about weather it was real or not. Live and learn on tractorbynet.!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ DK 55 Shuttle #37
I had a similar occurrence of this problem last fall. The growling noise was not very loud, but the transmission would not always engage after changing directions. The Kioti factory tech representative said that it was better to shift the shuttle lever while the tractor was still moving. That way the synchronizers are more apt to align. He suggested shifting into neutral and back to the desired direction, if the transmission would not engage. His suggestion worked and I have not had a problem since. He mentioned that if the shims were incorrectly installed the symptoms would be more severe. The way I try to change directions now is to press in the clutch, shift the shuttle while moving, let the tractor slow down to a creep and slowly let the clutch out. It's pretty easy to gauge how far the tractor will coast and if you need to apply some braking. It seems that the majority of the wear would occur on the clutch plates if you would let it out when the tractor was going too fast.
/ DK 55 Shuttle #38
I was out plowing the snow last night and decided I would give it shot. /forums/images/graemlins/blush.gif I shifted directly from reverse to forward and vice versa without a single problem. /forums/images/graemlins/laugh.gif
No grinding whatsoever!!! /forums/images/graemlins/grin.gif
RedDog
/ DK 55 Shuttle
Hey I am glad it worked for you.! Pretty nice ha. Did the plowing go faster.? Great to find out your tractor works better than you thought. /forums/images/graemlins/grin.gif
/ DK 55 Shuttle #40
I wouldn't say it went faster, but it was nice to know that it works!! /forums/images/graemlins/smile.gif
RedDog
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
2016 Peterbilt 579 (A60462)
2016 Peterbilt 579...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
CK350KW SKIDDED GENERATOR (A60736)
CK350KW SKIDDED...
2007 MACK CHN613 DAY CAB (A59906)
2007 MACK CHN613...
John Deere 5090GN (A60462)
John Deere 5090GN...
