DIY toolbox add
/ DIY toolbox add #1
Jimc295
Cleveland GA
Massey GC1705, Kubota B7100
I added a toolbox to my tractor and after using the loaded for a little while I've decided I do not like the location. It obscured my side view of the loader and so I can't tell when I have to bucket level with the ground so now I am thinking behind the seat.
/ DIY toolbox add #2
I put mine behind seat, Here are holes already in steel sub frame, I just had to drill through body.... Very disrespectful to all the safety labels though...
Might also want to look into "bucket position indicate" so you don't have to look around FEL frame work....
Dale
/ DIY toolbox add
Dale, that is what I was thinking about behind the seat. I had not thought of the position indicators though, thanks
Jim
/ DIY toolbox add
I finally got around to moving my toolbox to behind the seat took your advice Dale and disrespected the safety labels and used the underneath frame holes.
/ DIY toolbox add #5
Oooh, you guys inspired me to do the same thing. I have been wanting to add a tool box for a long time now. Are you guys just using ammo cans for the box? It looks like uni-strut to hold it?
/ DIY toolbox add #6
I had two toolboxes off a couple John Deere’s I’ve had over the years. The bracket mounts to the tractor and the toolbox is removable and also has a tray inside that can hang on the front. I mounted them on both sides of our ford and put a ford emblem on them. I don't know if these can still be bought from JD or not, my dad has an original one on his 1970 model 1020 he bought new.
/ DIY toolbox add #8
Yes on ammo can, 50 caliber sized will hold most anything you need..... And in my case it was some aluminum channel I had laying around I used to support "can" but it can be most anything that can be adapted....
No rules just make it work for you...
Dale
/ DIY toolbox add #9
Good idea - hanging the tray on the front. I think I will steal that one. When I need to get under the tray on my box I have to balance it somewhere or hold it. I was going to make some fold-out hinges but a couple hangers is easier. Thanks for the idea.
gg
/ DIY toolbox add #10
Here is my toolbox add.
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
Two (2) John Deere 5000-Series Tractor Grill Guards (A65640)
Two (2) John Deere...
2007 Freightliner Semi Truck (A66285)
2007 Freightliner...
213091 (A64276)
213091 (A64276)
2019 GMC Terrain, AWD (A62679)
2019 GMC Terrain...
13ft. Disc (A65640)
13ft. Disc (A65640)
