DIY Tire chains
/ DIY Tire chains #1
204saskman
Kelliher, Saskatchewan, Canada
Montana 2844R Hst
Now there is a sale on chain and im wondering if 3/16 chain is heavy enough. Now i kinda did a quick measure for my rear tires and i need 2x10'(20' of chain) and im guessing 20 18" cross links(30' of chain) So now i figured i needed about roughly 100' of chain but i was gonna get extra 50' as it never hurts to have extra chain around(might even get 100'). Now there is onlt about $0.60/foot from 3/16 to 1/4" chain but i was wondering if you really need the heavier chain. I could go to heavier no biggie, just wondering one weather or not its really needed. I figure i could build the rear set for under 250 with all of the cams and connectors. I currently have rear chains for my tractor but they are not wide enough and its gonna cost more for new cross links than it is to build new. I might reuse the sides but im not sure yet.
/ DIY Tire chains #2
Why don't you just put new cross chains on your existing chains instead building a whole new set? You can increase the chain witdth that way. I'd use as minimum of 5/16" chain because they take a beating especially if you use deicing chemicals. If your tractor has R1 tires then make what they call a "duo" cross chain; two cross chains held several inches apart with repair links about 1/3 of the way across in two places.
/ DIY Tire chains #3
The Duo grip has what is called a "H" pattern... It is probably the best way to go.
I agree that 1/4 inch is too small... the cross chain hooks would probably pull off before the side or cross chain breaks, but either way, 1/4 inch is far too small for that size of tractor... it is fine for small garden/lawn tractors tho.
I too recomend 8mm (5/16) side chain and minimum 7mm (9/36) cross chain, but 8mm (5/16) is a better plan.... most duo grip is 8mm
/ DIY Tire chains #4
You will need heavier for sure. If you are going to brew your own consider this design; I made a set for my F250 using this pattern. You don't need a welder, no cutting and splicing, chains are easier to put on because they don't slump as much as a straight bar type, and the anglular pattern runs smoother. You would get better traction with 'real' chains with v-bars, etc but I you want a cheap easy solution this might work for you.
This pattern is made from one continuous length of chain and the triangle tips are joined by clevises. Your local Princess Auto will have both go on sale periodically so you don't have much invested. If decide you don't like the tire chains, just undo them and you still have a nice long chain and a bucket full of clevises to play with :D
/ DIY Tire chains #5
I agree, 5/16 minimum for any kind of strength or lifespan.
Sean
/ DIY Tire chains
Only real reason i was gonna start from scratch is cause i have a use for the other chains. I might re use the outers of them and just replace the cross links. I called the local semi shop and at 8 bucks a cross link its cheaper to just use chain. I was gonna double up the amount of crosslinks. Im gonna call a different supplier about some chain today if i get time as i use chain around the farm for a bunch of different stuff.
/ DIY Tire chains #7
Interesting! Did you use a normal clevis or an "add a link" sort of thing? And are the sides of the triangles of equal lenght?
/ DIY Tire chains #8
I'd like to know what exactly these clevises look like, and the sizes of everything involved. This seems so simple and I like that. Can we get some pictures of them?
/ DIY Tire chains #9
Just a normal galvanized clevis; you can also use lap link chain splicer (you crush or hammer shut). I made the triangles to fit the sidewall overlap that I wanted. Took me a couple of tries to get the combination I wanted - after that just count links, clevis, count the links, clevis... the length over the tire is longer than the triangle base (sidewall length) - my drawing is not to scale. My guess is that the triangle base I used (for my 16" tires) used four links on the sidewall (with the trianglar pattern this would be approximately equivalent to a 2-link cross bar). The cross-over length would have been maybe ten links. I don't have them a work to count them but your tire size will be different anyway.
Nice thing is that you can experiment with any chain you have - once you have your pattern 'fingered' out - make your shopping list. Heck, you could even build these using 1/2 inch bolts - cheaper?
edit: Sorry, not a clevis, a shackle like this 5/16" High Tensile Galvanized Shackle | Princess Auto
/ DIY Tire chains #10
I was searching and finding those double ended chain clevises in the $7 to $10 range. A bit much. Changing the search to "shackles," I've already found 5/16" shackles for $1 to $2.
Do you wire down each screw pin?
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
TAKEUCHI TL6R SKID STEER (A59823)
TAKEUCHI TL6R SKID...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
44052 (A55852)
44052 (A55852)
