DIY Home built compact tractor
/ DIY Home built compact tractor
chrisser said:
GT2,
I'm new to the board, and joined specifically because of this thread.
I was searching the web for people building their own tractors. They are few and far between, and your thread is by far the best example.
Thanks for sharing it with everyone. Great info and pics - I sometimes check in twice a day to see your progress and read the comments.
- Chris
Thanks for the coments Chris, and welcome aboard!
/ DIY Home built compact tractor #183
DRL said:
FWD tractors can turn sharper than trucks because of how the knuckle is designed. They don't use U-joints, they use 2 pairs of bevel gears. One pair goes from the axle shaft to a short vertical shaft going down and the other pair from the bottom of that shaft to the horizontal spindle.
That's only in toy tractors like Kioti and Kubota. The only farm tractor using a driven front axle with this design is Belarus, all the other larger tractors use double U joints. Some of them might be using homokinetic joints like fwd cars.
Homokinetic?
Did something get lost in the translation?:D :D ( or maybe I'm ignorent)
Over here we call them constant velosity joints or CV joints.
/ DIY Home built compact tractor #185
GT2 said:
Homokinetic?
Title:Universal homokinetic joint Document Type and Number:United States Patent 4238936 Link to this page:Universal homokinetic joint - Patent 4238936 Abstract:Homokinetic joint of the type in which the torque is transmitted between two ends by balls engaged in races or tracks made in said ends.
Each track is constituted by two semi-cylindrical grooves, the sectional diameter of which being oriented relative to a radial axis passing through the geometrical center of the joint and perpendicular to the longitudinal axis of said two ends. The balls are thus made to roll and to be guided between two poles located on the radial axis and two other poles located on an axis perpendicular to said radial axis. Said arrangement excludes the use of any intermediate means for maintaining the balls on the bisecting plane of the joint.
The invention is particularly adapted to realize the two-joints transmission assembly for a vehicle.
I say Homokinetic, you say CV Joint / You say Potato, I say Potato :rolleyes:
See I am ignorent.
Next time my front wheel drive car has a clicking axle I'll be sure to ask for a new Homokinetic joint!:p
( I just wanted to say Homokinetic again):D
/ DIY Home built compact tractor #187
Wonder how many guys make a good living with "Toy" tractors like Kubota.
DRL
/ DIY Home built compact tractor #188
Be careful what part of town you are in when you say that. It could get you in a bar fight or propositioned? :D
/ DIY Home built compact tractor #190
DRL
Don't take offense, I am sure none was meant and is said in fun.
/ DIY Home built compact tractor #191
GT2 said:
Thats it? How come I'm not done yet?:D :D
Obviously, you've been spending too much time at the mall Christmas shopping!
I know if it was me, that list would get cranked out by the first week of January..... 2211!
jb
/ DIY Home built compact tractor #192
Same here
DRL
/ DIY Home built compact tractor #193
There are 2 ways to make a tractor have a smaller turn radius. One, is to have the wheels turn more (front, or back).
But, another way, is to shorten the wheelbase. So, if you aren't able to make the wheels turn more, why not shorten the WB if you can. You won't be sorry, unless you shorten too much and now can't carry anything in the FEL :eek:
/ DIY Home built compact tractor #194
One could also make the rear wheels turn in the opposite direction and/or articulate the chassis (or just the rear axle) to accomplish essentially the same thing.
Certainly both are much more complicated, especially with 4wd.
/ DIY Home built compact tractor #195
I make a living building 5th wheel trailers for dinky toy trucks like the Mercedes Sprinter ;)
/ DIY Home built compact tractor #196
Great, great thread GT2!
I daydream a lot while sitting atop my tractor mowing for hours, and think about all kinds of improvements. Most of the improvements would be to build tractors more user serviceable and cheap to repair. Some tractors have parts that are so expensive that if they break, it all but totals out the tractor. Having a frame not only eliminates expensive and delicate castings, but makes the machine a lot more versatile and easy to work on. Looks like your project is going to be as cheap and easy to repair as a tractor could get.
Good luck! Looking forward to more pictures.
Merry Christmas to all!
/ DIY Home built compact tractor #197
GT2, what is the status of the tractor? People have posted here from time to time about doing this, but no one has ever gotten this far along. Have you made any more progress?
/ DIY Home built compact tractor #198
You just described a tractor design as Versatile... that became a brand name for a tractor of that particular design ;)
/ DIY Home built compact tractor #199
GT2- how about an update, just so we know you are alive and well... You had too much accomplished to just up and quit!
Ha!! No I havent died!:)
Sorry I'm so slow, I'm working on buying some property in Idaho so I've been saving every dime and working on polishing up my present home to put up for sale in the future.
So... no progress, but the next step is motor mounts and drive line adapters!
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Miscellaneous Mini Excavator Attachments (A59228)
Miscellaneous Mini...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61166)
IMPORTANT PLEASE...
2019 Peterbilt 579 SLEEPER (A59905)
2019 Peterbilt 579...
