DIY Home built compact tractor
   / DIY Home built compact tractor #141
Glad to see that you are working on it again :D
When do you think it will be finished? :p
Well its been about a year and I'm about 1/4 done. Soooo that makes it about 3 more years?!:D :D :D :eek:
I lucked out on my wheel hunt at the bone yard!
I found two 14"x7" wheels and two 16.5"x9" wheels.
On the left are the orignal samuria wheels and on the right are the bone yard wheels. I start by carefully slicing thru the welds on the back side.
Then I sliced the rim from the back side being carfull not to cut into the center much. Here it is from the outside, you have to connect the slices in the middle.
A couple whacks with a hammer and out comes the center. Here is the backside.
Here I'm cutting the center out of the 16.5" wheel, I'm leaving a small lip in the wheel. 16.5" wheel with the old and new center.
The plan is to clean everything up and carefully weld the samuria center into the 16.5" wheel. It will look something like this.
   / DIY Home built compact tractor #144
Nice work :D :D
I hope it doesn't take another three years :rolleyes: :D ;)
   / DIY Home built compact tractor #145
This has been a most interesting project and I'm glad to see you are back at it. I thought you might have stopped completely, but seeing some progress now is good.
Very cool idea to cut those rims to use the Samuria wheel centers.
   / DIY Home built compact tractor #146
I wouldn't know how to fixture the wheels to get the center in the uh, well center.
Maybe you can show us how you are doing that? Or is it just +/- 1/8" and call it good?
jb
   / DIY Home built compact tractor #147
I'm also following this project and I can only say Wow! I've fabricated a lot of stuff in my time but I wouldn't even give a thought to attempting this project. You doing a great job and us back seat fabricators are really enjoying your efforts.
   / DIY Home built compact tractor #148
I'm also following this project and I can only say wow! I've fabricated a lot of stuff in my time but I wouldn't even give a thought to attempting this project. You'er doing a great job and us back seat fabricators are really enjoying your efforts.
Thanks for the kind words and input of ideas guys! I've learned a lot off this fourm.
I welded up the rear 16.5" wheels tonight.
After cleaning up all the surfaces I used thin alum "shims" in three places around the wheel center. I then clamped the center down and put 3 good tack welds in place to hold everything.
I then mounted the wheel up on the front hub and gave it the spin test.
Everything looks good with the spin test so I added 3 more tack welds to the back side and then proceded to weld the front side.
I welded in about 4" increments going back and forth 180* to spread the heat out evenly and hopefully keep the wheel from warping.
I then fliped the wheel over and welded the tacks into 1" long welds. After cooling down I mounted the wheel for another spin test,
and amazingly the wheels came out as perfect as my eye ball can detect!:)
   / DIY Home built compact tractor #150
Ya mean ya didn't put a dial indicator on them.:D At tractor speeds a little wobble is no big deal. I have recentered/reversed wheels and trued spokes with a dial indicator (a piece of wire for an indicator works pretty good too) and hub set-up but for what you're doing there is no need. Looks good!:cool:
   / DIY Home built compact tractor #151
With my luck it would look like a hola dancer!
Good job
jb
I thought about breaking out the indicator for about 2sec, then like you said, hey its a tractor! Not going to be breaking any land speed records!
I did cantaliever a 2x4 off the frame rail and next to the rim, its perfect!;)
   / DIY Home built compact tractor #153
Just for gits & shiggles, I'd be tempted to take it down to the nearest tire shop & see how it balances.
Like you say, it's a tractor, not critical...
But it'd be interesting.
She's a roller!:D :D
I've got about 10" of travel under the rear tire till the front axle hits the bump stops.
   / DIY Home built compact tractor #155
Thank the Lord Almighty for good 'ol yankee ingenuity! To paraphrase Mr. Foxworthy, "If you can build a tractor out of stuff lying around the yard, you might be a redneck!"
Come to think of it, if you have stuff lying around the yard that could make a tractor, you might be a redneck.:eek:
And proud of it, man.:D
:D :D
I've never been accused of being a redneck, I have however been accused of being a Concrete Dweller!!:p
I think redneck is better :D
   / DIY Home built compact tractor #158
WOW! Those wheels really turned out nice. I suspect this is homemade tractor is going to be a little nicer than many of the homemades that I see.
Keep the progress coming.
   / DIY Home built compact tractor #159
GT2, just one curious question:
Do these axles have different gear ratios to make up for the 2 different size of tires, or does the diff in the VW transaxle need to even that out ?
I'm not sure if the differential would be happy to turn the satelite wheels all day long. I think they are designed for incidental rotation just when you turn, not to even out 2 different ratios... ??
Yes I have a different ratio ( yet to be installed ) for the rear diff.
I'm going to eventually weld the "center" diff in the VW trans; If I dont any one wheel that slips would kill power to all the other wheels.
(2) 6 LUG 5200Ib-74SC-93 HUB FACE AXLES (A60432)
(2) 6 LUG...
gps trailers (A56859)
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
(4) MONTREAL RADIAL S/T 205R75R15 TIRES (A60430)
(4) MONTREAL...
