DIY Granite countertop?
   / DIY Granite countertop? #41
No way my wife would let that jagged edge in our mountain home.....I guess everyone has their preferences!
It looks good in a timber frame home. Not so good in a French provincial...
   / DIY Granite countertop? #42
My wife is the opposite. She loves timber frame, natural stone and hand hewn log accents. I happen to hew logs. .
   / DIY Granite countertop? #43
When we had our house built less than 1 yr ago, the granite counters were cut to approximate size with no cutouts. Then brought to the house and setup on saw horses in the back and they used angle grinders to finish up the cuts and make the sink cutouts. No wet saw!:shocked: We watched clouds of dust rise up over the house and drift on the breeze. The island has an 8' long straight edge, except it really isn't all that straight. Once they finished up, I took a cutoff and decided to see what I could do with it. I used an angle grinder with a 36 grit masonry wheel. It worked quite well and much better and easier than I expected. I did learn that I'd have to get much finer grits to get the proper polish. But the initial shaping was actually easy.
There are what are essentially router bits for granite that fit the angle grinders so you can have whatever edge profile you want. They're not cheap and take some skill to use, but . . .
   / DIY Granite countertop? #44
I was working a Lowe's when a customer came in wanting to grind a little bit off a granite vanity top. We looked at a couple options, none of which were very good or sure to work. As we were talking I finally asked him why he needed to trim the top. He told me there was a drywall seam that was in the way. I suggested he slide the vanity in place, scribe a line in the drywall even with the top and then sand away the drywall. He looked at me with that "slap your forehead" look and we both laughed about it.
Doug in SW IA
   / DIY Granite countertop? #45
No but honestly, I'd rather do it myself if it's possible. Not only do I save some money, especially when we get to the kitchen, it'll also be pretty satisfying to have done it ourselves. The only things we've hired out so far have been the HVAC and part of the drywall float/tape/texture. The drywall that we've done looks a lot better than what we paid the "pros" for...
Then use soapstone, a lot easier to work with.
   / DIY Granite countertop? #46
We were lucky enough to to find a large piece of granite for our kitchen island that was mis-ordered by the stone shop and was selling for $150.
As it was longer than we needed, the stone supplier made a cut and polished the end for...$150.
Still a deal for an 8 foot by 30 inch counter top finished to a high polish.
When we renovated our kitchen sink area we bought large pieces of soapstone from a local quarry and I cut, fitted and cemented the pieces together and finished them with hand tools and a good dust mask.
Total cost for the entire sink/counter surround was <$400 including some specialty saw blades, bits and adhesive.
And it is a really great surface.
I've already got the granite though, and it's the color she likes. We'd have to go buy soapstone...
   / DIY Granite countertop? #48
The live edge seems like a cleaning nightmare and even worse for sanitation.
Looks nice but even with a polished edge in our kitchen we had to cover a 2 foot section with clear packaging tape. My wife wore out a bunch of t shirts by leaning into the counter top doing dishes. Need it smooth.
I'm going with it's possible to DIY this. Better tools would make the job easier and I would suggest learning with a round over or bullnose instead of an ogee but, there nothing overly complicated here. I still have some polishing to do but, if you can finish auto paint or furniture, it's essentially the same process.
Pictures:
1 - The scrap granite
2 - Oh, the smell of Mainland China!
3 - Wet/dry diamond wheel, I trickled water on from the hose, couldn't feed through the arbor as pictured. Don't plunge all the way through with your cut on the first pass, score it about 1/8" and go another 1/8" on each successive pass until you're all the way through, you have more control that way.
4 - Start of the ogee
5 - After a couple of hours. I've started with the 200 grit wheel, still have a little shaping left to finish out and polish. My cut wasn't as smooth as it could've been so I've got to clean up the edge some as I polish it. IMG_20190107_141812289.jpegIMG_20190107_144346203.jpegIMG_20190107_145126145.jpegIMG_20190107_151740480.jpegIMG_20190107_155911021.jpeg
   / DIY Granite countertop? #50
That's coming along really nice. What tool did you use to create the ogee?
CAT CS563 (A47477)
CAT CS563 (A47477)
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
MISC LOT (A55745)
MISC LOT (A55745)
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2018 2018 JOHN DEERE 410L BACKHOE (A52706)
2018 2018 JOHN...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
