DIY: Bucket-mounted T-Post driver
/ DIY: Bucket-mounted T-Post driver #21
I saw the youtube video of the guy in Oklahoma.
Tee post Driver System - YouTube
Any concern in driving the t post in at the side of the bucket - unbalanced force on the front end loader. I would take a blank quick attach plate and rig it up in the middle so you get even load on the loader arms.
"or bend it". My soils are too hard except maybe in spring in some areas.
When you're driving it into soft soil its not a problem. Try some rocky soil and then you have a problem.
Yep that won't work around here regardless if you are on or off center with you FEL force. Glacial till is tough to dig or pierce.
/ DIY: Bucket-mounted T-Post driver #22
I live it in the cariboo, british columbia. I miss the soft soil from back in texas.
After digging out there, i'm finding almost all soil. I had to dig over 3' into the ground to find rocks. I'm hiring out for the H bracing and corner posts (welded steel pipes) and line posts. We're going to fill in the lines with T-posts then stretch 5 barbed wires. I'm sure we'll find a few rocks and bend a few posts but I have over 300 of these to drive in... not interested in pounding them by hand. Looks like the fence project will commence later in Sept. We're quite busy for a spell then need to first focus on the driveway before the permit expires.
/ DIY: Bucket-mounted T-Post driver #25
GOOD LORD man, where did you live? Must have been E Tx as here in the Tex Hill Country, which is just one big, BIG Rock. Top soil if you have 6 in then you are extremely lucky...
The property we bought is in Lampasas county. My only complaint is the honey mesquite... Giant weeds with big taproots!
/ DIY: Bucket-mounted T-Post driver #27
You are so correct, houston, texas. But grew up in the texas hill country in uvalde county. My after school job was doing fences with my grandfather so I have lots of caliche experience, but the prarie soil is so soft and all east texas is also soft. There were many times when only a jackhammer did the job. In the cariboo canada I've had to hire fencing guys that have to pound a pilot hole before putting in a post. I've also dug many holes by hand and you are lucky if you dont hit a 40 lb rock. World of difference.
/ DIY: Bucket-mounted T-Post driver #28
Let me put it this way, we dug lots of holes in with an auger in texas. But the auger just dances on top here in the cariboo.
/ DIY: Bucket-mounted T-Post driver #29
Vibrating pounder on a bobcat works great.
Sent from my SGH-I337M using TractorByNet mobile app
/ DIY: Bucket-mounted T-Post driver #30
I don't need to "make something" to put in T post...
I load my loader bucket with everything I need, then I can get off the tractor and start a T post with a sledge, get back on the tractor and push it in with the bucket. Having a "helper" in a HUGE time saver...
Hard ground? For those, I use a bucket full of dirt to push them in, if that doesn't do it, then a post pounder won't do it either!
SR
/ DIY: Bucket-mounted T-Post driver #31
Those T posts bend awful easily.
/ DIY: Bucket-mounted T-Post driver #32
SR
**** yeah! Try finding someone to help and i pay well when i do find someone. Usually its the wife. Then she wants me to sleep with her as partial payment.
Are you thinking of the cheap formed metal ones or the solid steel ones? The ones we are putting in aren't Home Depot garden ones. 😉😎
/ DIY: Bucket-mounted T-Post driver #34
Are you thinking of the cheap formed metal ones or the solid steel ones? The ones we are putting in aren't Home Depot garden ones. dde09dde0e
The solid ones from any of the local farm stores. They bend if you try to push them into hard rocky soil.
/ DIY: Bucket-mounted T-Post driver #36
Doesn't sound like you are very good at that job, cuz if you was, it would cover the WHOLE payment!!
SR
/ DIY: Bucket-mounted T-Post driver #40
I made one that goes on the side of my bucket and it twist the loader a good bit when in hard ground. I'm going to move it so a hay spear I have and mount it in the center. IMG_1346.JPG
2014 F-150 4WD (A63689)
2014 F-150 4WD...
2022 EZ-GO ELITE...
Cute Electric Car (A62679)
Cute Electric Car...
40ft 10 Door Shipping Container (A64194)
40ft 10 Door...
2014 MACK CXU613 SLEEPER (A65643)
2014 MACK CXU613...
12T Shop Press (A66408)
12T Shop Press...
