diverters or third function OR
/ diverters or third function OR #1
LouNY
Super Star Member
Greenwich, NY
Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
You know with the cost of these third function controls and or diverters I am surprised that more people haven't just installed another valve in the power beyond line, either a joystick or 2 or 3 stack valves and operators. All the people with the top and tilts think how intuitive a joystick would be to adjust your level, and the variety of spools available with stack valves, metering, float, motor, detented, with load checks and then using cable operators to mount them remotely.
/ diverters or third function OR #2
The advantage of a 3rd function or diverter is having the switch or switches right on the loader joystick. So you don't have to move your hand to open or close the grapple or do whatever's on the loader using hydraulics. I have a simple spool valves mounted on the fender with the handle pointing towards the joystick. I don't have to move my hand far but I do have to move it and that slows me down a bit. Eventually I'll build a 3rd function setup for it.
/ diverters or third function OR #3
Surplus Center stocks a joystick valve with a third valve using a separate lever. I used it to add 3rd function on a previous tractor. Worked well but no comparison to push buttons on joystick handle.
/ diverters or third function OR #4
/ diverters or third function OR #5
To put aditional axis on a joystick is about impossible if it isn't electric over hydraulic, and most loader valves are direct lever actuation or cable actuation, so to get more function, you'd need a second joystick or other aditional levers.
Were I starting from scratch, I think I'd rather have an electrohydraulic system with a 4 or more axis joystick (or whatever I had availiable). Starting with an existing loader, I'd go with diverter valves.
/ diverters or third function OR #6
I agree. All construction equipment has went to electro. Joysticks with switches and twist action that perform half a dozen functions.
2008 CATERPILLAR TL642 6600 LBS TELESCOPIC FORKLIFT (A64047)
2008 CATERPILLAR...
(NEW) 12 BLADE GROUND BOG HARROW (A63290)
(NEW) 12 BLADE...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
Kubota BX2370 (A62180)
2005 Isuzu NQR 4 door box truck with folding gate (A63118)
2005 Isuzu NQR 4...
