Diverter Valves
/ Diverter Valves #1
ns_in_tex
Platinum Member
East Texas
Kubota L4610 HSTC, International 2400, Hesston 1280,
Can anyone give me a good source for a 6 port, 12 volt, spring loaded, electric diverter valve for hydraulics? This would be to operate a grapple with electric button on the joy stick of my fel.
/ Diverter Valves #3
Tell me more about the grapple!!! /w3tcompact/icons/grin.gif
I want one!! /w3tcompact/icons/love.gif
/ Diverter Valves
OK,
The guys on tbn got me started on this by showing their brush grapples. I looked at prices & had to do a little more thinking.
I already had a set of forks with a grapple that I could slip a gin pole on. so they had to stay unmodified. Came up with this to slip on forks for brush. Works great. Only wanted electric diverter valve so wouldn't have to move hand from joy stick to rear remotes to operate grapple.
/ Diverter Valves
Brush forks with closed grapple
/ Diverter Valves #6
Check EBAY search under 'hydraulic valves' I'v seen them there from time to time real cheap.
/ Diverter Valves #7
ns_in_tex,
The V&M</font color=blue> website popped up in an hydraulic thread earlier this year. They seem to make a selection of electrically powered hydraulic diverter valves. Good luck.
OkieG
/ Diverter Valves
Thanks,
I'll check it out.
/ Diverter Valves #9
Okie,
Here's the "How to" from the FAQ's here.
{url}http://www.whatever.com/{/url} = Makes the given url into a link.
{url=http://www.whatever.com/}title{/url} = Makes the given title into a hyperlink pointing to link.
Just use the "[" and "]" brackets instead of the "{" and "}" I used to illustrate it here.
So it's either your link
/ Diverter Valves #10
Thanks Gary,
Appropriate adjustments have successfully been made. I'd never looked at the FAQs before. That answers alot of my questions. Duh! Now I can free up a couple of my faulty gray cells and use them to half-remember something else.
OkieG
/ Diverter Valves #11
Thanks Okie,
I missed the link the last time it came up. Bookmarked it this time. One of those would be quite the ticket for the forklift.
Nick
/ Diverter Valves #12
MDNick and ns_in_tex,
One more possible source is one of the front blade (snow blade) companies that offer hydraulic options on their blades.
A few months ago I called CurtisCabs about the front blades they make. They offer an electric diverter valve retrofit which creates an extra set of loader frame quick connects. The control button mounts as a thumb switch on the SCV lever. This would be used in their application to angle the front blade to left or right. I got the impression they would be glad to sell the diverter valve as a separate unit.
Their 1-800-number is on their website at CurtisCabs</font color=blue>.
OkieG
/ Diverter Valves
Thanks,
I'll check into it.
/ Diverter Valves #14
Neal:
I got my diverter kit from W .R. Long, in Tarboro, NC. They don't have a website, but their phone is 1-800-823-4570.
I have their 4 n 1 bucket, for which the diverter kits are assembled.
A thread on the diverter on my Power Trac is at
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=powertrac&Number=200406&page=2&view=collapsed&sb=5&o=0&fpart=>DIVERTER LINK</A>
You might also try Bailey, which sells a lot of different hydraulic cylinders, valves, etc. I have found them helpful on the phone and fast delivering. <A target="_blank" HREF=http://www.baileynet.com>BAILEY</A> Phone 1-800-800-1810
Good luck.
/ Diverter Valves #15
Ooops. I have a correction to make. Charlie's post above reminded me.
When I called and found a manufacturer willing to sell just the diverter valve, it was Long not Curtis. Although, Curtis might also sell a solo diverter valve. I have talked to both companies, but it's been a while and I got them mixed up.
OkieG
/ Diverter Valves
Charlie,
Do you know the brand & M# of the valve you used?
I looked at your installation instructions & found them to be exact as the instructions on the Gresen valve which I purchased locally & iinstalled. It does work, but it will not apply near as much pressure to the cylinder as when it is hooked to the rear remotes. Also the specs say it will leak 20 CIPM @ 2000 PSI @ 128 deg F.
Do you, or anyone have any idea why the no power?
My valve was a Grensen MS06-UDNA-01-12B.
/ Diverter Valves #17
Neal:
I do not know the brand and model number of mine. I looked at it before I mounted it, and found no data plate. I suspect it is a Gresen because that seems a dominant brand, and there is probably a cast logo on it somewhere.
Mine seems to reduce the rate a bit, but not the pressure. That is pure impression, however, since it hooks the lines to a completely separate circuit from that previously used, so the difference may not be the valve, at all. The tilt function (Valve inactivated) seems unaffected, so there really isn't reason to suspect that flow is much affected when the diverter valve is activated.
The lift and tilt hydraulics all have a fairly fast leakdown rate on the PT, even cold, so leakdown in the new valve wouldn't be noticable.
2010 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2010 ALLMAND...
2003 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2003 INTERNATIONAL...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2005 Peterbilt 357 Tri-Axle Dump Truck (A66736)
2005 Peterbilt 357...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2017 Ford F-250 Ext. Cab Knapheide Service Truck (A66736)
2017 Ford F-250...
