Ditching Bucket
/ Ditching Bucket #1
Sfrankland
Newfoundland
Mahindra 5010 Cab, Kubota U35-4
Been wanting to build a 24" ditching bucket for sometime now so last night I started cutting out the parts for one. I used my current factory made bucket as a template and made patterns out of cardboard. The sides are 1/8" plate with a 1/4" tops edge. The bottom of the bucket is also 1/8" and the cutting edge is 3/4". My plan now is to build a quick attach system so I can quickly switch between my regular bucket, ditching bucket and ripper (yet to be built).
/ Ditching Bucket #2
Excellent, Ive planned on making a cleanout/ditching bucket since I bought my BX. Just waiting on my new welder.
Im a little surprised at it being 1/8", I thought the metal on my bucket was a bit thicker, 3/16 maybe. Ill have to double check.
Curious to see how well it works.. I was planning on going up to a 30" and was unsure Id have enough power.
/ Ditching Bucket #5
Nice work . How do you do all that welding and not turn it into a pretzel ?
/ Ditching Bucket
Lots of tacks and checking your work as you go. Once it's tacked good stitch weld it so your not putting to much heat into the parts.
/ Ditching Bucket
Made a quick attach for the backhoe bucket. It should be ready tomorrow once the paint is dried. Need to pick up a few extra 1" pins so I can leave them in the buckets.
/ Ditching Bucket #8
Neat! :thumbsup:
Here is a ripper tooth you can put on it, might need an adapter though. :D
/ Ditching Bucket
Neat! :thumbsup:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=318195"/>
I think I may have to rebuild the whole backhoe to get it to fit. Very impressive ripper though. What's it used on?
/ Ditching Bucket #10
A big excavator, I found it on an image search looking for a ripper tooth for my box blade.
This is the Website: Products | PSM
/ Ditching Bucket #11
Very nice fabrication work, I'd love to have one of those for my BH.
/ Ditching Bucket
I got a video of it that I am waiting to finish uploading. Had to shoot it in the garage because of this beautiful Victoria Day weekend weather. Beats the 35cm they got in Gander though.
/ Ditching Bucket #14
Awesome job on the bucket and Q attach. By the looks of your video, it works spot-on!
/ Ditching Bucket #16
Isnt 1/8" a little thin. My bucket is 3/4" thick. Its heavy as heck.nice build btw. I want a 39" for mine to ditch with but I want to build a tilting bucket. Im sure I can do it, just gonna take time.
/ Ditching Bucket
My cutting edge is 3/4" thick and the top edge is 1/4". The lower sides and the curved bottom is 1/8". My factory 16" bucket is built the same way and has held up perfectly while digging very rocky dirt with a lot of big rock. With the 1/8" plate being bent in an arc and welded solid it has a huge amount of strength vs just a flat plate. Same idea as a steel culvert.
Having it tilting would be very useful. Looks like another build maybe in the works.
/ Ditching Bucket #18
that is really slick. givin' people ideas and stuff ;)
/ Ditching Bucket
After 204saskman planted the idea of a tilting function I did some reading and found a quick coupler with tilt and rotate functions built in. I won't be building the rotator function but the tilt function would be handy to use on different buckets. I have plans on adding a hydraulic thumb so I could make it so I could use the same hydraulic valve for the tilt or the thumb just not both at the same time.
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
UNUSED X-STAR GRAVEL LEVELER (A64280)
UNUSED X-STAR...
2015 Nissan Sentra Sedan (A61574)
2015 Nissan Sentra...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
2012 Ram 1500 Crew Cab Pickup Truck (A61573)
2012 Ram 1500 Crew...
Crustbuster 6020 TW36X6 (A64119)
Crustbuster 6020...
