ditch digging/clearing
/ ditch digging/clearing #1
RedTailHawk
Capon Bridge, WV
Kubota L3430
What attachment do you use to create and maintain roadside ditches?
I found this modified box blade with a middle buster bolted on to the side. I知 not sure if it is offset enough from the tractor tire. Otherwise the tire would just mash down the edge of the ditch and then the middle buster has more to clear out.
Do you know of any tools, tips, techniques for digging and maintaining roadside ditches?
/ ditch digging/clearing #2
A rear blade tilted and angled will cut a ditch and keep it cleared.
/ ditch digging/clearing #3
I've given a lot of thought to doing something like in the picture...but I do have good success using my rear blade to clean out 6' of ditch at a time/pass...
I set up perpendicular and back the blade to the back side of the ditch and lower the 3ph...then slowly moving forward I extend the (hyd.) top link curling the blade forward and raising the 3ph so the blade with the ditch debris slides up and over the near side of the ditch and onto the road...if it's mostly gravel and sand (fines) I re-spread if it organic matter I move it off with the loader...
/ ditch digging/clearing #4
I suspect the attachment combination pictured was cobbled together for something other than cleaning road side ditches but haven't a clue what it's purpose is....
/ ditch digging/clearing #5
I have a very light scrapper blade but it keeps the small ditch on the side of my house cleaned out good enough.
/ ditch digging/clearing #6
This,
and I lock my lower links all the way to the side.
In the picture above see how the blade is all the way to the left.
2017 International 4300 Box Truck (A62613)
2017 International...
1996 International 4700 (A64127)
1996 International...
Woods 1050 3-Pt Backhoe (A66285)
Woods 1050 3-Pt...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2012 International DuraStar 4300 Digger (A62613)
2012 International...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
