disk ripper
   / disk ripper #1
mulitweed
john deere
I have a small garden patch, an old disk some chisel plow shanks plenty of iron would be nice to make a ripper , one day , i plowed ny corn ground last year worked ok nice to get those stalks buried
   / disk ripper #2
I recently restored this, it was my brothers. The nice thing is, the tools can be swapped out for other types too.
Not certain the size of your machine. This is for garden tractors or small SCUTs. Something larger would need to be made otherwise for a bigger CUT machine.
   / disk ripper
thanks , too small i have 620 Jd , M ih , and 3320 Jd
   / disk ripper #4
I must be missing something. Are you saying you have built that unit or asking for ideas on such?
Not sure have ever seen a riper with disk blades to cover in the same implement. But sure there are out there, to many options not to be.
If you are building one as I think you are talking about rippers and blades to turn the soil to cover the trash; believe the HP required would surprise many people. If you are talking about an unit for say a single row you are about five feet wide. I would think you would want three rippers for that width. For certain two. Rippers depending on depth and ground need a good bit of HP. I pull two subsoilers with nothing else and it gives my 68 HP Kubota all it wants on our soil. Rock free for info. Now that is pulling them at least 18 inches deep to maybe 24.
Then to add blades to that I think you will basically at least a single gang disk axle of blades with it.
I may be way off what you are looking for but I would lean towards a ripper followed by disk heavy enough to cut and cover the crop debris.
   / disk ripper #5
   / disk ripper
thanks , looking to bury and bust up the stalks , looking for ideas to build a mini ripper
Kubota L4701 (A53317)
New/Unused Agrotk YC-26G Sawmill (A57453)
New/Unused Agrotk...
2015 Chevrolet Express Box Truck, VIN # 1GB3G3CG3F1110762 (A57453)
2015 Chevrolet...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59575)
1999 TRANSCRAFT...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
