disk for a 640 ford tractor .
   / disk for a 640 ford tractor . #21
3pt disc's are good for smaller tractors that you can transport on a trailer. a drag disc is usually larger / longer and is made to road transport.
i would not want to do a large are disc job with a smaller 3pt.. but they sure do pick up and go easier...
   / disk for a 640 ford tractor . #22
no external hyds needed either!
   / disk for a 640 ford tractor . #23
Of the 3 types of disk: 3-pt, drag, and hyd. lift, There is no doubt that the 3-pt is best for small gardens. That is the main reason they are so popular. On them little gardens, a rototiller would be better (get the soil worked quicker and use less fuel, unless the soil was rocky). Another reason for the 3-point's popularity, for non-rocky ground, on small gardens, is that many folks cant swing the extra cost of the rotiller, or don't want to deal with the greater complication. Anyone using a 3-pt, on more than 1/2 acre, is probably burning double the fuel, to get the job done, than they would with either of the two pull-type disk's (drag, and hyd. lift). As the cost of fuel continues to rise towards the stratosphere, the 3-pt disks are likely to loose some popularity for folks working more than 1/2 acre or so.
found a old ford disk for $456 out the door at houser and son down in chillicothe,ohio
   / disk for a 640 ford tractor . #25
Good for you. If it is in usable condition that sounds like a good buy to me. Hope you get a lot of use out of it. :thumbsup:
   / disk for a 640 ford tractor . #26
Did you happen to check at Mike's..?? Both are good to deal with..!! I can speak for Mike, and my buddy deals with Houser a lot. He is his go to guy for accessories.
I hope it works well for you..!! Pics..??
   / disk for a 640 ford tractor . #27
good price ifot rusted out and no bearings!
   / disk for a 640 ford tractor . #28
3pt disc's are good for smaller tractors that you can transport on a trailer. a drag disc is usually larger / longer and is made to road transport....
This is how poster's terminology here on TBN gets me (an admitted novice) confused. I have two old "drag" discs, and since they have no wheels at all, I doubt I'll be doing any "road transport!"
   / disk for a 640 ford tractor . #29
Before getting a transport disk, the neighbor did, and guess Dad did too when disking the neighborhood gardens he'd plowed. There was no doubt when he/they were headed for home..!!
2015 Volkswagen Jetta TDI Sedan (A50324)
2015 Volkswagen...
SET OF SKID STEER QUICK ATTACH PALLET FORKS (A51242)
SET OF SKID STEER...
Semi Roll-off 2 Axle Trailer (TITLE) (A50774)
Semi Roll-off 2...
Kubota 48in Bucket (A50322)
Kubota 48in Bucket...
E-Z TRENCH GROUND SAW (A51244)
E-Z TRENCH GROUND...
CLASS ROLLANT 160 HAY BALER (A51243)
CLASS ROLLANT 160...
