disk for a 640 ford tractor .
   / disk for a 640 ford tractor . #21
3pt disc's are good for smaller tractors that you can transport on a trailer. a drag disc is usually larger / longer and is made to road transport.
i would not want to do a large are disc job with a smaller 3pt.. but they sure do pick up and go easier...
   / disk for a 640 ford tractor . #22
no external hyds needed either!
   / disk for a 640 ford tractor . #23
Of the 3 types of disk: 3-pt, drag, and hyd. lift, There is no doubt that the 3-pt is best for small gardens. That is the main reason they are so popular. On them little gardens, a rototiller would be better (get the soil worked quicker and use less fuel, unless the soil was rocky). Another reason for the 3-point's popularity, for non-rocky ground, on small gardens, is that many folks cant swing the extra cost of the rotiller, or don't want to deal with the greater complication. Anyone using a 3-pt, on more than 1/2 acre, is probably burning double the fuel, to get the job done, than they would with either of the two pull-type disk's (drag, and hyd. lift). As the cost of fuel continues to rise towards the stratosphere, the 3-pt disks are likely to loose some popularity for folks working more than 1/2 acre or so.
found a old ford disk for $456 out the door at houser and son down in chillicothe,ohio
   / disk for a 640 ford tractor . #25
Good for you. If it is in usable condition that sounds like a good buy to me. Hope you get a lot of use out of it. :thumbsup:
   / disk for a 640 ford tractor . #26
Did you happen to check at Mike's..?? Both are good to deal with..!! I can speak for Mike, and my buddy deals with Houser a lot. He is his go to guy for accessories.
I hope it works well for you..!! Pics..??
   / disk for a 640 ford tractor . #27
good price ifot rusted out and no bearings!
   / disk for a 640 ford tractor . #28
3pt disc's are good for smaller tractors that you can transport on a trailer. a drag disc is usually larger / longer and is made to road transport....
This is how poster's terminology here on TBN gets me (an admitted novice) confused. I have two old "drag" discs, and since they have no wheels at all, I doubt I'll be doing any "road transport!"
   / disk for a 640 ford tractor . #29
Before getting a transport disk, the neighbor did, and guess Dad did too when disking the neighborhood gardens he'd plowed. There was no doubt when he/they were headed for home..!!
2010 Case 660 Trencher (A50322)
2010 Case 660...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
2022 PETERBILT 579 DAY CAB (A50854)
2022 PETERBILT 579...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
