We're getting going on our first acreage. I won't re-hash everything here, see following link for some info on the process of getting our tractor going.
www.tractorbynet.com
The tractor is a 1968 International 444 with the gas engine, 2wd. It has a rear drive tire track width of about 82". It does not have wheels/axle that can narrow up (another recent issue I am digesting - it is problematic for plowing).
What I have now is a jumbled mess of 1/8 acre of plowed ground. It was ripped a couple weeks before which is what I believe caused the top sod/root structure to clog the plow a lot = the jumbled mess you see.
We're going to let the ground settle for some time. I am hoping maybe after a month or two, especially if we get some rain, the lumps will settle a bit. The goal is to get in there with a disk to further level it and mix it.
That brings me to the thread discussion. What I think I want right now is an 8' drawn disk with transport wheels. 7' might work, that is 84". 8' is 96". That will cover up the track width of the tractor.
I did come across a 12' disk for a reasonable price. It is about 70-75 road miles from the farm and would have to be towed straight, no trailer. That wouldn't be a task for the tractor, better tow vehicle. Though, I am not sure of the weight of the disk or if the tires would make that distance.
Another route might be a 3pt mount, instead of a draw type. What I don't like about this is it would pull rigid to the tractor (no pivot for turning) and it would require mounting to the 3pt to move it, as opposed to hooking the drawbar and pushing/pulling it around to reposition.
Last note - it is possible to get access to a rototiller/tractor for the initial breaking down + mixing up of the soil/organic matter. I am tempted to do that this first year, however I have a desire to keep the operation to more traditional processes. Even though tractors already are "mechanized", the mechanics of using a PTO driven implement to do the tillage/ground prep is, to me, too "mechanical" - active, not passive like pulling a plow or disk.
For the 2025 growing season we won't have any mechanized planting equipment. That said, I am not too worried about a 100% smooth seed bed like what a field cultivator/chisel plow would leave. However, if I could get a rolling basket behind the disk that would help the leveling some more.
Can you interpret what you see and what I have described and offer any advice/input? If it were you and your farm - how would you approach the issue?
International 444, 1968. Progress Thread, Getting Going
For quick reference here are a couple other related threads: Pre-purchase - International 444 gas - been sitting for years. Trailering - Trailer rails are 76" apart, tractor with wheels is 82" wide - take wheels off? We just bought a 1968 International 444. For some of the details on condition...
