Discarding used hydraulic/transmission fluid?
   / Discarding used hydraulic/transmission fluid? #31
i prefer to take it oil recycling so that it goes back into the oil food chain. Just my :2cents:
   / Discarding used hydraulic/transmission fluid? #32
It came from the Ground, why not put it back there?
BTW - I did do that, 40 years ago...
   / Discarding used hydraulic/transmission fluid? #33
I hear that, and that's always a good option.
But for the sake of arguments, when it's dumped in with used dirty engine oil, it simply looks like used, dirty engine oil.
Nobody would have a cause to ask what it is.
   / Discarding used hydraulic/transmission fluid? #34
The one in Clallam County (Port Angeles) also takes used oil filters.
I usually build-up a certain amount of them in a box, then take them there.
-No more mess in the garbage.
   / Discarding used hydraulic/transmission fluid? #35
can it just be filtered and reused? seems like a tremendous waste to me. Although I've been known to keep a few gallons and use it for cutting oil on the drill press and in the oil can for various uses.
   / Discarding used hydraulic/transmission fluid? #36
I just did a horrible (and highly elusive) hydraulic repair job. Man, a lot of oil got away on me. At $100.00 / pail! Sometimes the harder you try to be responsible, the worse it gets! Finally, you just say F$%$% it!
   / Discarding used hydraulic/transmission fluid? #37
   / Discarding used hydraulic/transmission fluid? #38
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2016 Fiat 500X AWD Hatchback (A56859)
2016 Fiat 500X AWD...
25ft Tag Trailer (A56435)
25ft Tag Trailer...
2013 Peterbilt 367 T/A A-Frame Gin Pole Truck (A55973)
2013 Peterbilt 367...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
