Discarding used hydraulic/transmission fluid?
   / Discarding used hydraulic/transmission fluid? #31
i prefer to take it oil recycling so that it goes back into the oil food chain. Just my :2cents:
   / Discarding used hydraulic/transmission fluid? #32
It came from the Ground, why not put it back there?
BTW - I did do that, 40 years ago...
   / Discarding used hydraulic/transmission fluid? #33
I hear that, and that's always a good option.
But for the sake of arguments, when it's dumped in with used dirty engine oil, it simply looks like used, dirty engine oil.
Nobody would have a cause to ask what it is.
   / Discarding used hydraulic/transmission fluid? #34
The one in Clallam County (Port Angeles) also takes used oil filters.
I usually build-up a certain amount of them in a box, then take them there.
-No more mess in the garbage.
   / Discarding used hydraulic/transmission fluid? #35
can it just be filtered and reused? seems like a tremendous waste to me. Although I've been known to keep a few gallons and use it for cutting oil on the drill press and in the oil can for various uses.
   / Discarding used hydraulic/transmission fluid? #36
I just did a horrible (and highly elusive) hydraulic repair job. Man, a lot of oil got away on me. At $100.00 / pail! Sometimes the harder you try to be responsible, the worse it gets! Finally, you just say F$%$% it!
   / Discarding used hydraulic/transmission fluid? #37
   / Discarding used hydraulic/transmission fluid? #38
INBOARD DRIVE (A58374)
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
Bucket Truck (A55973)
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
2000 TRAVIS BODY & TRAILER, INC. 39 END DUMP TRAILER (A58214)
2000 TRAVIS BODY &...
